Author Topic: External resistor for coil ???  (Read 1122 times)
Offline 4406v
« on: June 17, 2015 - 09:06:10 AM »
I removed an external resistor mounted to the coil  mounting bracket and connected to one of the posts on the coil of my 383. Putting it back together I can't remember which post it goes on + or - ??? I think it's the negative but want to be sure.
"Live for today, Tomorrow never comes"
Offline tman
Re: External resistor for coil ???
« Reply #2 on: June 17, 2015 - 11:02:55 AM »
I think he's talking about the AM radio capacitor that mounts to one of the coil bracket bolts.  I think that gets attached to the + side.  I'm researching it now.  I know the tach wire gets connected to the - side.
Edit...It does go on the + side of the coil.  It's there to prevent noise in the AM radios...nothing else.
« Last Edit: June 17, 2015 - 11:07:17 AM by burdar »
Offline 4406v
« Reply #3 on: June 17, 2015 - 12:46:03 PM »
The coil is marked "Must use external resistor" and it had one mounted. If it's just for radio noise no problem I won't need it What's a radio for??? Can you really hear it over a Big Block at W.O.T.???
« Reply #4 on: June 17, 2015 - 12:54:58 PM »
The ballast resistor is for the coil.  The small capacitor on the coil is for the radio.
Offline 4406v
« Reply #5 on: June 17, 2015 - 04:26:30 PM »
So it's on the negative post?
« Reply #6 on: June 17, 2015 - 09:11:38 PM »
Positive post.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: June 18, 2015 - 01:04:15 PM »
Radio would require a positive connection.  :bigsmile:
