Author Topic: 1970 gran coupe steering cloumn key/cylinder rotation problems  (Read 541 times)
Offline culp71
all,
1970 Plymouth gran coupe barracuda steering column..
rebuilding steer column, but when I put all pieces back in the key cylinder and ignition switch travel is limited by the "wheel lock piece" (picture spring loaded tab) I matched all parts to ones that came out, all appear to be identical, but it does allow me to remove the key, because it cant rotate far enough.\
If I take this wheel lock tab piece out all works fine, any idea as to what could be the problem?
thanks
Offline 1 Wild R/T
Re: 1970 gran coupe steering cloumn key/cylinder rotation problems
« Reply #1 on: June 17, 2015 - 02:33:12 PM »
Is the linkage connecting  the transmission to the steering column in place?  It may need adjusting....  Grab the collar closest to the dash & rotate it fully counter clockwise As viewed from the drivers seat....
