Author Topic: Need pics 4 speed install cuda  (Read 2486 times)
Offline cudaguy71
« on: June 17, 2015 - 04:14:41 PM »
Can someone please provide some good, clear, big somewhat, pics of where the bracket goes on the front frame rail?
Also, when cutting for a four-speed hump, how much do you go in from scribing around the hump?  1"?  Can someone provide good pics installed both top and underside (w/o the tranny installed)?
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
2003 Dodge Dakota Sport
1979 Plymouth Arrow
Offline vinb
Re: Need pics 4 speed install cuda
« Reply #1 on: June 17, 2015 - 08:57:00 PM »
Here are a few pictures of mine,
I used 3/16"  rivets and seam sealer top & bottom instead of welding it in, just in case I want to go back.
Offline Those
« Reply #2 on: June 17, 2015 - 09:03:37 PM »
When I cut mine I left about 1/2 to an inch for welding. After I was done sometime later I read an article that said only cut whats in the way. The more metal you leave the stronger it will be. I don't know if that's true but I kinda wished I had checked first to see how much metal I could have left.
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: June 17, 2015 - 10:51:42 PM »
Here are the pictures of the Z-Bar Pivot bracket.  There is a small notch on the frame rail (all cars have it). It really only goes in one way, so it is pretty easy.
Offline mauls
« Reply #4 on: June 18, 2015 - 12:17:57 AM »
What kind of rivet gun did you use?  I'm looking for a good one to get the job done
Kansas City, MO
1970 Challenger &2010 Challenger SRT8 six speed
Offline vinb
« Reply #5 on: June 18, 2015 - 07:33:23 PM »
Rivet gun , your basic piece of (you know).. hold tight and do it up.
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #6 on: June 20, 2015 - 09:30:15 PM »
« Reply #7 on: June 20, 2015 - 09:31:04 PM »
Offline Haddixj
« Reply #8 on: June 21, 2015 - 11:19:34 AM »
As far as leaving metal in there, would you be concerned with leaving a pocket for stuff to sit in from the road? What do the factory cars look like? Thanks
