Author Topic: After 15 mos finally going to the dyno.  (Read 8693 times)
Offline roadman5312
Re: After 15 mos finally going to the dyno.
« Reply #15 on: June 20, 2015 - 03:18:41 PM »
    520 crank, 465 rear wheels    :drunk:
Offline Mopar Thunder
« Reply #16 on: June 20, 2015 - 06:32:39 PM »
Cool setup. How many lbs. of boost are you running?
Thanks, Max will be 20 lbs.
« Reply #17 on: June 20, 2015 - 06:46:07 PM »
Since I have to put in a new fuel system and then go back to the dyno shall we guess on the numbers at the fly wheel from the engine dyno numbers I already have? It may take till after Carlisle before I am able to get the car to the dyno again for rear wheel numbers.
« Last Edit: June 21, 2015 - 03:57:49 PM by Mopar Thunder »
Offline 69ChargerRT
  • Its the car, right? Chicks love the car. - Batman
    • Daisy - My 1969 Dodge Charger R/T
« Reply #18 on: June 22, 2015 - 10:03:14 AM »
id say around 500 crank sounds about right, so ill go 440 to the wheels
Offline Oldschool
  • Member Since 9-05-06
« Reply #19 on: June 22, 2015 - 10:42:01 AM »
585 CRANK.  495 REAR WHEELS
Ken  --  In Georgia
Offline jimynick
« Reply #20 on: June 22, 2015 - 10:47:47 PM »
I think you boys are wildly underestimating the potential of this "small" block. Based on the gear, I wouldn't be surprised to see over 600hp NA and over a 1000 on the pump, depending on fuel and boost. This is one bad-a$$ Mopar and I can't wait to see where it ends up. Glad I'm not paying for either the powertrain of fuel!!  :thumbsup:
« Reply #21 on: June 23, 2015 - 12:46:57 PM »
 8)   does anyone want to see the crank numbers or should we wait to see the rear wheel numbers also?
Offline 67vertman
  • Member since 9-23-2005
« Reply #22 on: June 23, 2015 - 12:49:39 PM »
I vote for giving it a couple more days to see if anyone else chimes in......then give us the flywheel numbers.
Then we can play rear wheel HP.
P.S. Does the winner of the fly wheel numbers get a ride along?  :poopoke:
Offline ToxicWolf
« Reply #23 on: June 23, 2015 - 05:14:11 PM »
470 at the crank.   :2thumbs:
Offline jimynick
« Reply #24 on: June 23, 2015 - 10:29:08 PM »
Yeah, I'm talking at the crank, too.  :wave:
Offline RCCDrew
« Reply #25 on: June 29, 2015 - 05:13:16 PM »
Yeah, 1000 at the crank at 20 psi.
Offline roadman5312
« Reply #26 on: June 29, 2015 - 05:18:30 PM »
                             Now this is getting a little out of hand here   :roflsmiley: :smilielol:    1000 HP   :22yikes:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #27 on: June 29, 2015 - 05:28:23 PM »
Considering my buddy's duster made around 800 at the crank from a stroked 340 that was naturally aspirated on race has, I'm gonna say this one, supercharged, I'm gonna say about the same, 800 crank hp.  Cough up the crank numbers man!!!
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline RCCDrew
« Reply #28 on: June 30, 2015 - 11:26:17 AM »
In theory, 14.7 lbs of boost will double the N/A number.  So if you are at 20, with a 450 hp motor...
Offline HP_Cuda
  • Mopar or No Car!
« Reply #29 on: July 01, 2015 - 02:50:35 PM »
That also depends if you are at sea level for atmospheric pressure.
