Ok, I found the green wire from the clutch pedal. It goes through the firewall and has a male bullet terminal on the end of it. I guess I will have to make a short wire with a female bullet connector and a female spade connector to complete the connection to the starter relay.
I also found a round grommet behind the brake pedal with two wires going through it into the engine bay about 16-18" long. There is a green wire and a blue wire and both have female spade connectors on the end of them. Any ideas what these wires are for?
Thanks!
Jeff
