Author Topic: MSD, Pertronix, FBO. I'm lost  (Read 3548 times)
Offline Fern
« on: June 18, 2015 - 08:17:39 PM »
Ok, I have a late model 440 low compression motor. I am putting in a Hughes whiplash cam, and RPM intake. I have a cheap distributer with orange box (was bought off ebay). I'm thinking of upgraging the ignition system. I do want a distributer which can control advance.
Do I need a complete system or just a distributer? Orange box or MSD?
What is the best option?
Thanks
Offline cudabob496
Re: MSD, Pertronix, FBO. I'm lost
« Reply #1 on: June 18, 2015 - 08:44:24 PM »
MSD system, IMO
2011 Kawasaki Z1000
« Reply #2 on: June 18, 2015 - 09:47:45 PM »
Factory system with a Rev-n-ator ECU , at least you can get parts at any parts store
« Reply #3 on: June 18, 2015 - 10:06:35 PM »
No reason why the FBO is any different.
If it crapped out, (which it won't) put a mopar ECU in, remove the bypass wire on the ballast and get going again.
« Reply #4 on: June 18, 2015 - 10:22:45 PM »
Yup
Just reluctant to trust FBO after prior experiences
« Reply #5 on: June 18, 2015 - 10:59:24 PM »
Yup
I've heard at least a few saying the Rev n Nator crapped out and you saying the FBO did as well.
At least the FBO has a 3 year warranty.
Pick your poison.    :2cents:
« Reply #6 on: June 18, 2015 - 11:40:20 PM »
True
Offline cudabob496
« Reply #7 on: June 19, 2015 - 12:14:04 AM »
so, does the Rev-N-nator make all the power that was promised?
2011 Kawasaki Z1000
« Reply #8 on: June 19, 2015 - 10:20:14 AM »
Yup, everything breaks.... At some point.
I installed an MSD box and am happy with it, so I recommend them. Others had the MSD box crap out on them, so those guys say the MSD is a pos. All comes down to personal experiences.  :2cents:
« Last Edit: June 19, 2015 - 10:23:20 AM by dodj »
Offline roadman5312
« Reply #9 on: June 19, 2015 - 10:35:56 AM »
Were going to use the MSD-6AL-2, the newest version. It's smaller and supposed to be a better product. Time will tell.
Offline Fern
« Reply #10 on: June 19, 2015 - 05:38:01 PM »
So I guess its all personal preference and which one lasted longer?
I think I'm leaning towards FBO, but if they are all pretty much the same I will just go with one that dosent cost an arm and a leg!
Thanks
« Reply #11 on: June 19, 2015 - 10:00:12 PM »
FBO box is made in U.S.A.
Is the MSD or the Rev N Nator made here as well?
Offline 73440
« Reply #12 on: June 19, 2015 - 11:10:00 PM »
Rev-A- Nator says Made in USA on paper.
MSD does not say where made, makes me think Chi Coms, was really surprised by that.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Fern
« Reply #13 on: June 20, 2015 - 03:04:51 PM »
The Rev N Nator still requires the use of the ballast resister. I would like to remove it if possible. Otherwise it sounds like a great option.
Now I need a good distributer that is easy to set advance on.
« Reply #14 on: June 20, 2015 - 04:40:54 PM »
FBO is a 12V system to the coil. Is the Rev N Nator?
