It depends how easily it will turn , , you want .008 - .010 end play .
I use a pin punch or screwdriver to turn it , when you get close hit the end of the axles with a hammer to make sure the brgs are fully seated to make sure the end play is set correctly .
Make sure you pack the brgs with grease before installing as they will be dry / no grease from the diff
