Author Topic: Go wing location?? AND install...........  (Read 1594 times)
Offline DAYLEY/CHALLENGER
« on: June 19, 2015 - 04:43:43 PM »
  I have a new item to install....go wing.   Can someone post the factory location.  I also have the under lid brackets.  Drilling into original metal....scary when you may not be completely correct.   Thanks in advance, Dave.
« Last Edit: June 24, 2015 - 03:34:33 PM by DAYLEY/CHALLENGER »
Dave or David
Re: Go wing location??
« Reply #1 on: June 19, 2015 - 05:48:27 PM »
the brackets underneath should only fit in one place & should line up the hole locations for you
« Reply #2 on: June 20, 2015 - 07:42:39 PM »
So correct Chryco .  After I figured out which side  was which  on the brackets it all fell into place.  I am working from an IPad right now but maybe getting  a desk top tomorrow.  Then I can post some pics the right size for the forum. All went well, no extra holes and  she has already been out for a test flight.  More larer. ...thanks, David
Dave or David
« Reply #3 on: June 20, 2015 - 09:46:29 PM »
 :2thumbs:
Offline Racer57
« Reply #4 on: June 20, 2015 - 11:26:53 PM »
What degree of tilt is proper ?  I loosened up the Allens on mine and played around with it some.
« Reply #5 on: June 21, 2015 - 09:54:20 AM »
Proper ?
 Well every Ford owner has it wrong marching the wing angle to the back window add loft to the rear of the car , I guess ford owners are not taught aerodynamics LOL .
 SO the wing should be nose down 3* or so , more nose down will increase downforce on the rear of the car , no right or wrong as to haw much angle you set it at
« Reply #6 on: June 21, 2015 - 08:26:54 PM »
Ok trying to post a couple of pics now.............I think it turned out great...............By the way.........the go wing came from Dante's along with all the hardware. I am very pleased with the quality of all the parts..........
« Last Edit: June 21, 2015 - 08:29:30 PM by DAYLEY/CHALLENGER »
Dave or David
« Reply #7 on: June 21, 2015 - 08:28:09 PM »
Looks great  :2thumbs:
Offline roadman5312
« Reply #8 on: June 22, 2015 - 09:28:19 AM »
                         Lookin fine,  ready for takeoff.     :2thumbs:
