Author Topic: Axle endplay on 8 3/4  (Read 641 times)
Offline bucknbass
« on: June 20, 2015 - 10:10:54 PM »
Thanks to several on here I was able to adjust the RR axle endplay on my '73 Challenger successfully but I have probably twice as much on the driver side which I know isn't adjustable?  Seems like when I had the RR adjuster all the way in there was no endplay on the driver side but when I unscrewed the RR adjuster to about where I thought it should be the driver side endplay showed up.  Does this make any sense?  Should I have endplay on the driver side too?
Offline 1 Wild R/T
Re: Axle endplay on 8 3/4
« Reply #1 on: June 20, 2015 - 10:21:27 PM »
The adjustment on the passenger axle adjusts both sides, the thrust transfers from one axle to the other either through a thrust block or thrust pins...   Personally I like to run the adjuster down to zero end play then back it off two notches... Not much at all....
Offline crash340
« Reply #2 on: June 20, 2015 - 10:40:45 PM »
Thats pretty much how its done, just might have to pound on it with a dead blow to seat the bearings and axles to make sure the adjuster winds down to zero before backing off two notches
Greg
73 Cuda
Brisbane, Australia
Offline bucknbass
« Reply #3 on: June 21, 2015 - 10:33:36 AM »
Got it just right I believe!  Appreciate the help.
