Author Topic: Brake trouble  (Read 4367 times)
Offline Fern
Re: Brake trouble
« Reply #15 on: June 22, 2015 - 06:56:25 PM »
Any chance the star wheel adjusters are locked up too far?
Checked the shoes, they are correct. Adjusted the star wheel out for play and no difference. Drive backwards with brake on for adjustment and still the same. The adjustment wheel does work.
need info on the rod length.
Re: Brake trouble
« Reply #16 on: June 24, 2015 - 08:44:39 AM »
Basically it need to just touch the piston the rear of the master but not depress it at all .
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Brake trouble
« Reply #17 on: June 24, 2015 - 06:07:01 PM »
I searched the interweb some for a rod length and so far only info is that the power booster for disk brake style has a shorter rod , but haven't found an exact  size
« Last Edit: June 24, 2015 - 06:09:48 PM by 72rtchallenger »
72rtchallenger
what happens in the garage
stays in the garage
Offline Fern
Re: Brake trouble
« Reply #18 on: June 24, 2015 - 06:43:06 PM »
I've been all over the Web also with no luck
Re: Brake trouble
« Reply #19 on: June 24, 2015 - 08:43:21 PM »
The rod a 2 piece unit & is threaded / adjustable
