Author Topic: a 904 filter  (Read 551 times)
Offline brotow
  • There really is a Challenger in the backround
a 904 filter
« on: June 22, 2015 - 10:26:42 AM »
I'm I missing something?  On valve body where the filter mounts shouldn't there be a a "nipple" that goes into the filter? Also the Trans Go shift  kit I installed came with a "mesh" type filter similar to the factory fiber filter except there are two holes for trans fluid.
« Last Edit: June 22, 2015 - 10:29:16 AM by brotow »
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Re: a 904 filter
« Reply #1 on: June 22, 2015 - 10:47:07 AM »
There is a gasket between the valve body and the filter...that's it.  The mesh filter lets more fluid flow through it.  It probably doesn't filter as much as a stock filter though.  I've got the mesh filter on one of my 904s.  I'm curious what the trans gurus say about it.
Offline brotow
Re: a 904 filter
« Reply #2 on: June 22, 2015 - 12:08:30 PM »
I kinda remember a black rubber "sleeve" that was on the filter. I have not used the transmission so I don't know the history of it.  The filter that was mounted in the transmission did not have any gasket, the mesh filter from the shift kit does not have a gasket?
Re: a 904 filter
« Reply #3 on: June 22, 2015 - 12:20:53 PM »
I'm pretty sure mine has a gasket.  I googled "904 trans filter" and this image popped up.
http://www.msprodimages.com/images/T/TCI/TCI128500.jpg
Offline brotow
Re: a 904 filter
« Reply #4 on: June 22, 2015 - 12:38:25 PM »
The triangular gasket is the one that goes under the filter. I also found out the filters two holes are for, one for the front pump and the other for the rear pump. The original filter had only one hole.
