Author Topic: Giving up on OEM Booster and Master C  (Read 4120 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« on: June 22, 2015 - 11:29:50 AM »
Can anybody recommend the best brake booster and master combo to purchase out there?   Mine are needing to be rebuilt and I'm not wanting to rebuild something that can be improved.
71' cuda 383 - front disc/rear drum - currently has a pancake and master c setup.
What would you put on?
Want one?  Got one! ... finally
Re: Giving up on OEM Booster and Master C
« Reply #1 on: June 22, 2015 - 12:18:02 PM »
do you have power steering ? I would install a hydro boost system
Offline anlauto
« Reply #2 on: June 22, 2015 - 12:28:38 PM »
Is there a part number casted into the bottom of the master cylinder ? I may like to buy it from you... :bigsmile:
Offline wantone
« Reply #3 on: June 22, 2015 - 12:37:44 PM »
Car has a firm feel power steering setup.
Can you post a link etc so I know what to buy?
Offline djw383
« Reply #4 on: June 22, 2015 - 01:38:56 PM »
Call DoctorDiff.com and tell him what you have now and how you want the pedal to feel and in what application and he will hook you up. If not oem, the newer aluminum mc that don't leak are nice...
Sent from my HTC6525LVW using Tapatalk
Offline 1 Wild R/T
« Reply #5 on: June 23, 2015 - 12:02:21 AM »
If you pull an OE booster to put in an aftermarket POS your a fool..... I just went through is with a guy with more dollars than sense... He started having a hotrod shop rip out the old OE Bendix booster & install a new MP booster.... The car stopped terrible, they replaced the MP Booster three times... Then they sold him a Hydraboost system... It stopped ok but the pedal always felt weird, kinda like a HD truck... Finally I got talked into looking at it... Now it has a rebuilt OE Bendix booster, a new master cylinder & it stops like a new car.... So after spending $2700.00 he has what he started with...
Get your stock booster overhauled, Sell Alan your stock MC core if it's the pt # he's searching for & put a new stock MC on the car... If your looking a Wilwood brakes or something like that you might need a different bore size on the MC but keep your stock booster.... :2cents:
« Reply #6 on: June 23, 2015 - 01:24:45 AM »
Get your stock booster overhauled, .... :2cents:
Brake Booster Dewey is who can re build it for you.
Offline djw383
« Reply #7 on: June 23, 2015 - 07:27:08 AM »
I upgraded to this with no issues and the car stops like a dream, I have a pretty good cam and no hydraboost is needed. I get staying with OEM, so this is a good compromise.. http://www.doctordiff.com/bendix-style-dual-diaphragm-booster.html . If you are happy with the booster you have then stick with it...I also switched to silicone fluid so I have no worries of the fluid eating the paint if it leaks or when bleeding....
« Last Edit: June 23, 2015 - 07:39:55 AM by djw383 »
Offline wantone
« Reply #8 on: June 23, 2015 - 11:27:34 AM »
OK - so I looked at the bottom of the MC and it's Bendix # - 223085_?_7
I have my doubts about this being even for an E-Body.   I bet this was a B body part or something.   It's a Bendix so it's not a reproduction.
« Last Edit: June 23, 2015 - 12:25:08 PM by wantone »
Offline 4406v
« Reply #9 on: June 23, 2015 - 04:58:27 PM »
I used a Master Power Brakes booster master cylinder and proportioning valve on my 440 six pack Challenger with great results. Just make sure they send you the master cylinder that looks like a Chrysler unit NOT the GM looking one. I installed the set up ,bled the brakes and never touched it again!!!
"Live for today, Tomorrow never comes"
Offline reborn73
« Reply #10 on: June 23, 2015 - 09:57:40 PM »
It all depends on if you are wanting to stay with OE style or resto mod.  I used Booster Dewey to rebuild my Booster and bought an OE MC from theramman.com in Texas.  Couldn't be happier with the results. BUT, I was going for as close to OE as possible, not performance minded.
Offline wantone
« Reply #11 on: June 24, 2015 - 04:16:37 PM »
OK -  So seeing as how the master cylinder isn't worth crap and the booster is likely toast -
Do I go with the Napa - http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Power-Brake-Booster-w-Master-Cylinder/_/R-NBB503705_0136024600
or the
Pirate Jack bendix double style - http://www.piratejack.net/index.php?route=product/product&path=152_129&product_id=441
Again -  My M.C. looks to have no value outside of being from Bendix and somewhat period correct / and i don't suppose the brake booster is any good as booster dewey guys said it sounds F'd out.
So - Spend 385 or spend 135?     Car has P/S   P/B   Front disc and Rear Drum.   Cruise se-up.
Offline djw383
« Reply #12 on: June 24, 2015 - 04:22:38 PM »
Call Doctor Diff, get a aluminum mc and a double bendix booster, I love it.
Offline Falbz
« Reply #13 on: June 24, 2015 - 04:36:29 PM »
Id personally go the Napa route with your car for a more OE correct look and to retain the value of your 71.  I am sure it will more than suit your needs and save you some coin.
I am running that pirate jack setup (MPM Booster setup) on my 69 Charger without any issues but the car originally came with 11inch power drums up front.  If you do go that route classic stocks those setups locally as well  :2cents:
« Last Edit: June 24, 2015 - 04:43:12 PM by Falbz »
Offline 72ls5fla
« Reply #14 on: June 24, 2015 - 06:51:54 PM »
I would just send Dewey your booster and get it rebuilt.
He is a class act guy and the booster I had him do came out perfect !
He did one for me on a Vette too.   perfect.
Bill
