Author Topic: AMD 4 speed manual sheet metal with Tremec  (Read 660 times)
Offline mauls
« on: June 22, 2015 - 02:09:53 PM »
I think I already know the answer to this question, but i'm currently converting my car to a manual  transmission.  I was going to buy the AMD patch panel that goes into the floor to clear the shift rods.  I was curious if this patch panel will also work with the Tremec 5 speed transmission.
thanks
Kansas City, MO
1970 Challenger &2010 Challenger SRT8 six speed
Offline roadman5312
Re: AMD 4 speed manual sheet metal with Tremec
« Reply #1 on: June 22, 2015 - 02:23:33 PM »
                    Works good   :2thumbs:
Offline mauls
« Reply #2 on: June 22, 2015 - 02:29:18 PM »
Thanks for the reply.  I''ve read with the 6 speeds you have to cut more of the trans tunnel out but the 5 speeds should fit right in if i'm correct.
Kansas City, MO
Offline anlauto
« Reply #3 on: June 22, 2015 - 03:00:37 PM »
Yes 6 speeds have a "center mounted" shifter, while the 5 speeds have a shifter in the stock location :2cents:
Offline Racer57
« Reply #4 on: June 25, 2015 - 10:38:37 PM »
If your using the Tremec now, then do not fasten the panel down until you have the tranny mounted and drive line angles all checked out. Its a lot easier to get the clearances that way. Just in case.
http://www.cuda-challenger.com/cc/index.php?topic=107058.0
