Valvoline Gear Oil
Author Topic: Valvoline Gear Oil  (Read 1747 times)
Offline Bluemonster71RT
Valvoline Gear Oil
« on: June 24, 2015 - 09:45:41 PM »
The center section I bought from Mancini Racing has on the break-in steps paper what oil to use but specifically says "Do Not Use Valvoline Gear Oil" any one know why? I have Valvoline gear oil already. The diff is a Auburn Pro series. Nowhere on the Auburn web page does it say not to use that oil. I have emailed Mancini but haven't received a response. Just wondering if any one else knew anything.
1971 Challenger RT 383 4spd
Re: Valvoline Gear Oil
« Reply #1 on: June 24, 2015 - 09:48:50 PM »
no clue but oil is cheap so why risk it
« Reply #2 on: June 24, 2015 - 09:55:20 PM »
Because it was already put in prior to getting the sheet. So if I don't have to pull it all apart just to drain the oil would be a good thing at this point.
Offline BS CUDA
« Reply #3 on: June 24, 2015 - 09:59:03 PM »
DO NOT RUN SYNTHETIC OIL!!!!!!!!!!!!!! Straight up 80w90 dino oil only with a limited slip additive. Perhaps Valvoline is a semi syn :clueless:
« Reply #4 on: June 24, 2015 - 10:03:26 PM »
Seems to be all good. sae 80 90w  made out of real dinosaurs.
« Reply #5 on: June 25, 2015 - 12:39:40 AM »
a $14 suction gun will suck most of the oil out in minutes without disassembling anything
« Reply #6 on: June 25, 2015 - 06:17:02 AM »
I was hoping that would work.
« Reply #7 on: June 25, 2015 - 08:50:59 AM »
Since you bought it from Mancini, call them and ask them about it.
« Reply #8 on: June 25, 2015 - 11:57:20 AM »
Here's the reply I got today
:Valvoline just doesn’t have the reputation it once had. So we recommend using a different brand plus the Mopar friction modifier for the sure grip. I would remove when you can & put in a name brand like Kendall 80/90. Thanks.
So it's just that they don't like it.
« Reply #9 on: June 26, 2015 - 10:31:45 AM »
Or they have found the oil quality to be substandard & damaging parts
