Author Topic: Steering radius on 73 Cuda  (Read 4070 times)
Offline 1 Wild R/T
Re: Steering radius on 73 Cuda
« Reply #15 on: June 30, 2015 - 11:28:08 AM »
These cars all have bump steer issues. Unequal length tie rods don't create just additional bump steer issues, but can impact a difference right to left in radius.
To some extent true, however compared to GM & Fords offering Chrysler was miles ahead & with minor tweaks it can be eliminated..   However one tie rod an inch longer is going to cause that side to react completely different from the other side...
Offline Lbs
« Reply #16 on: June 30, 2015 - 11:33:34 AM »
I'm on my way there now.......these comments are coming with me. I'll let you know what is found. Thanks everybody for your ideas.
Sent from my iPad using Tapatalk
Offline Lbs
« Reply #17 on: June 30, 2015 - 02:04:14 PM »
And I'm back........... It appears I have the wrong center link in the mix. It looks to be too short and is throwing off the whole works. Does anybody have the  dimensions of the correct center link for a 1973 plymouth cuda or maybe know where I can look them up. Thank you
Offline Lbs
« Reply #18 on: June 30, 2015 - 06:29:40 PM »
Ok, hopefully this is the end of this adventure. The center link that is on my car has a center to center measurement of 18 5/8ths inches from the idle arm hole to the pitman arm hole. That # is supposed to measure 20 7/8ths C C. I found one and should have it in a few days. Thank you to all for your thoughts and ideas.
Offline 1 Wild R/T
« Reply #19 on: June 30, 2015 - 07:09:24 PM »
Just went & measured mine 20 7/8 is correct... Good catch... :thumbsup:
