, I would pass on a Tremec behind a 512 stroker making that kind of power , I doubt it would last , I installed one behind a serious Hemi & was disappointed , I did not shift well & the driveline angle was off .
I used approx 12 440 Source kits to build 512 strokers , A close friend did all the machine work & did all the short block assy , I chose the parts list -pistons , cams , heads , intakes , carbs , rockers , I did the top end assy ordered custom pushrods etc . Oddly one of our customers chose not to pay me & decided not to call me for help after that , the engine started to run poorly & he had no clue how to make it run right so he decided to blow it up & claim warranty , last laugh was on him , he badly damaged the engine bending a couple of the con rods etc but the engine would not blow up , finally brought it back to us & admitted what he had done after we called him on it , cost him another 5k to have the engine rebuilt properly again !
For EFI I used
- SDSEFI computer
http://www.sdsefi.com/- an Accufab 1200 CFM Throttle body as it was the shortest one I could find
- Eddy Victor intake with fuel rails this has the T body on top of the intake , now I see they have a forward facing intake with rails that will take 150 mm T body or bigger
- 2 Walbro inline fuel pumps 250 lt / hr
- Bosch 75 lb / hr injectors
- Bosch fuel pressure reg set for 55 psi
- I had the balancer drilled with magnets exactly 90* apart & built my own bracket for the crank trigger / pick up
- I used stainless JIC fittings everywhere as they are $5 each instead of $40 for AN
- I ran 3 3/8 steel lines 2 with a dedicated Walbro pump to each fuel rail & a 3rd as a return line
- I used a single coil & a dist instead of a multi 4 coil pack with wasted spark but the SDS can run multi coil pack instead of a dist .
I think that was all of the parts ?
