Author Topic: Centrifugal Superchargers  (Read 3542 times)
Offline bigblue73
Re: Centrifugal Superchargers
« Reply #15 on: June 30, 2015 - 11:35:02 AM »
Here is what I have come up with and is 95% of the direction that I am proceeding with.  I'm using a Paxton SN-93 head and routing it to the airbox which will encase the throttle body.  The fuel injection will outside of the bonnet and the manifold will be dry versus a wet set-up (much  like the FAST EZ-EFI)  In keeping the injectors out of the bonnet, removes all the electronics to the outside where I can mount a TPS sensor to the Air horn shaft.  Fuel will be boost referenced at 1 lb. of fuel pressure increase to each lb. of boost.  The most I will ever run is 10lbs. of boost.  My kicker in this whole thing is to run this under the original Mr. Norms supercharger bonnet.  It does not have to be this complex.
« Reply #16 on: June 30, 2015 - 11:37:47 AM »
This might take some looking , I know they use larger screw blowers on Hemis
 I wounder if the have any simple solution to use the smaller blowers on a 440 or if you would have to work an adapter plate between a regular blower intake & a screw blower
Offline Spartan040
« Reply #17 on: June 30, 2015 - 02:04:38 PM »
I thought Procharger only did superchargers for modern Challengers?
« Reply #18 on: June 30, 2015 - 04:20:19 PM »
Summit carries Paxton , Procharger , Vortec & RIPP
 This is Whipples site http://whipplesuperchargers.com/index.php?dispatch=pages.view&page_id=14
Offline Spartan040
« Reply #19 on: June 30, 2015 - 07:37:50 PM »
Can a Whipple be made to work on a 440? I like the sound of them. Also, Summit only carries the Paxton for big blocks
« Reply #20 on: June 30, 2015 - 07:43:11 PM »
I sent them a question about doing that
Offline Spartan040
« Reply #21 on: June 30, 2015 - 07:50:48 PM »
Awesome, thanks very much. Also, I'm thinking I want to go with the Edelbrock Pro Flo XT EFI system which uses a cold air intake instead of an air cleaner, thoughts?
