Author Topic: Clutch selection  (Read 1209 times)
Offline BB73Challenger
Clutch selection
« on: June 28, 2015 - 08:34:59 PM »
So I think I'm going to give Brewers a call and line up some new pieces parts.
Anybody is welcome to chime in on thoughts and opinions.
The car has a 500 ci stroker
M/T ET streets
full steel car
99% street with a trip or 2 annually to the track
So honestly more street than strip but my concern is a weak clutch kit will be "beat up"
or even ruined by more engine than clutch, but I'd also like it to not chatter like crazy too.
ALSO, I'm a machinist / tool and die maker by trade, and I would think a blanchard grinder
would be good for resurfacing my flywheel, sound OK?
I have no problem with the B&B style clutch but get this, I have been using no overcenter spring.
Stupid question, but would picking up a new one from Brewers help on overcoming some of that
clutch pedal effort?
SO I'm thinking without talking to them...
A McLeod 10.95 Performance clutch package
Kit to rebuild the z-bar
and a new overcenter spring
Hit me, what you think?
Jeff from Cleveland, Ohio
Re: Clutch selection
« Reply #1 on: June 28, 2015 - 11:42:55 PM »
sounds right but there are a number of choices -
 first overcenter spring is a must & will help pedal pressure !
 There are approx 6 different clutch disc facings , feramic is brutal but will take the heat no prob but no slip , more like an on & off switch  , Kevlar is often used , semi metallic , on & on .
 Pressure plate again you have choices , 3 finger B&B or my Fav is the B&B Long hybrid , lighter pedal using better leverage  but great grip , diaphragm not what I recommend at all , too many issues & Mopar was never designed to use them so ratios are wrong etc . There are different pressure ratings also .
 I used a Street twin with a B&B Long PP , it uses twin discs & will hold more power than I will ever make , I may have cut some corners in my resto but not in the drivetrain areas !!
 Talk to McLeod & Brewers tell them what you have & see what they recommend
Offline 1 Wild R/T
« Reply #2 on: June 29, 2015 - 01:38:37 AM »
You might look at this thread..
http://www.cuda-challenger.com/cc/index.php?topic=106839.msg1050215#msg1050215
Craig @ CJD Automotive has a brand new Mcleod Street Twin Clutch for sale.... He's sold the Tremec & assorted parts but still has some parts.. Don't know if the discs are different for the Tremec or if they are 18/23 spline... Could be worth a phone call...  His price on the package was pretty good, since he split it up you might catch a deal...
« Reply #3 on: June 29, 2015 - 08:42:05 PM »
The street twin can have 3 different Pressure plates , B&B , B&B Long or diaphragm so be careful .
