Author Topic: Can you identify where these wires go?  (Read 1470 times)
Offline jmartin99
« on: June 30, 2015 - 08:42:12 AM »
I am putting together a '72 Challenger Rallye for a friend and I have a pair of wires that were taped together almost the whole span. They are in a round grommet that goes through the firewall behind the brake pedal. I looked at a firewall picture on here that identifies what each hole in the firewall is for and these wires gor through the backup light hole. They are a green and a blue wire and both have plastic shielded female spade connectors on them. they extend about 16-18" into the engine bay. Here is a pic of them...
Any ideas where these wires are supposed to go? What they are supposed to attach to?  :dunno:
Thanks!  :1zhelp:
Jeff
Offline anlauto
Re: Can you identify where these wires go?
« Reply #1 on: June 30, 2015 - 08:48:18 AM »
I would start on the other side of the firewall and see where they come from....that might give you a clue to their purpose :2cents:
Offline jmartin99
« Reply #2 on: June 30, 2015 - 09:09:55 AM »
Yeah, I thought about that.
I looked at the wiring diagram in the service manual and it does not show a grommet with those two colors of wires going through the firewall.
I will look under the dash tonight to see if I can identify where they go.
Jeff
Offline annularnos
« Reply #3 on: June 30, 2015 - 10:47:30 PM »
Green and blue....look like alternator field wires to me.
« Reply #4 on: July 01, 2015 - 06:54:36 AM »
I will agree with you if they are long enough to get to the other side of the engine. :2cents:
Offline anlauto
« Reply #5 on: July 01, 2015 - 07:34:08 AM »
Is the harness originally from an A/C car ?
Offline Blasterb
« Reply #6 on: July 01, 2015 - 08:37:35 PM »
Look like A/C wires to me. Blue one goes to the compressor, green one to the horn
Offline jmartin99
« Reply #7 on: July 02, 2015 - 08:39:23 AM »
They are no where near long enough to get to the other side of the engine let alone the front of the engine.
I have not had a chance to see where they go under the dash yet. Maybe tonight or tomorrow.
Thanks!
Jeff
Offline anlauto
« Reply #8 on: July 02, 2015 - 11:48:25 AM »
Maybe they're exiting the firewall in the wrong location...that's what's throwing you off ? Is it an A/C harness or car ?
Offline Blasterb
« Reply #9 on: July 02, 2015 - 05:02:09 PM »
Could go to your blower motor. mine is green. my horn wire is actually green with a red tracer.
Offline jmartin99
« Reply #10 on: July 07, 2015 - 03:42:45 PM »
I have looked under the dash. The wires are taped together by themselves and go up next to the main wire cluster behind the instrument cluster and then it is hard to tell where they go. I was trying to figure out a way to determine where they go but have not come up with a good solution yet.
Originally the car was not an A/C car. BUT the owner wanted A/C and had a donor car and had the firewall section welded in to make this an A/C car. I have new wiring harnesses for the engine bay and I already have the compressor and horn wires. Maybe the blue one is the blower motor wire?
Thanks!  :clapping:
Jeff  :banghead:
