Author Topic: What rims and tires for b body rear?  (Read 4360 times)
Offline RCCDrew
« on: July 02, 2015 - 01:50:22 PM »
I just put an early b body (66) rear and Dr. Diff kit in my car. Now I need some new rims and tires to fill out the wheel wells. What wheel tire combo are you using after making this swap? I tried a search and couldn't get what I was looking for.
Offline 69CHARGERMD
Re: What rims and tires for b body rear?
« Reply #1 on: July 04, 2015 - 09:01:21 PM »
Check out my thread.
I have a dr diff b body Dana
Not sure how big a tire you want
http://www.cuda-challenger.com/cc/index.php?topic=107097.0
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
« Reply #2 on: July 04, 2015 - 10:50:13 PM »
Dana 60 B-body width from Cass ,I have 18x 11" rims with 5.5" backspacing with 295/40/18 with lots of clearance could have went slightly bigger?
« Last Edit: July 04, 2015 - 10:53:03 PM by brads70 »
Offline RCCDrew
« Reply #3 on: July 05, 2015 - 01:46:02 AM »
Did you do the 1" or 1.5" spring relocation? Mines the 1".
Offline RCCDrew
« Reply #4 on: July 05, 2015 - 01:50:18 AM »
Checked out your thread. You can put more rim back there can't you? An 8" rim and 295 tire. Especially with the relocation kit.
Offline 69CHARGERMD
« Reply #5 on: July 05, 2015 - 07:52:21 AM »
With that tire a bigger rim might be tight side to side,,,,it was perfect with the 8 ",,,,anything wider and I think it would rub on my application
For me,,,,the 8 " rim seemed to work best,,,,,
I have the 1.5" off set shackles
What tire size are you going to run,,,,,?
Doug.
« Last Edit: July 05, 2015 - 07:56:25 AM by 69CHARGERMD »
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
« Reply #6 on: July 05, 2015 - 08:09:27 AM »
I'm pretty sure it's the 1" offset but I'll get under the car and measure the spring perches to double check. I'll get back to you......
Offline RCCDrew
« Reply #7 on: July 05, 2015 - 10:48:34 PM »
Thanks! Wow 11" is a lot of rim. Now I have to find out what's available. Pre b body rear I was running a 275/40/17 tire on a 17x9.5 rim. Kinda didn't want 18s because they make my rear drums look dumb, lol.
« Reply #8 on: July 05, 2015 - 11:02:12 PM »
44" centers so that's a 1" offset.  Falken specs a 10-11.5" rim for that size tire and the tire section width is 11.8" so tire will still rub before the rim will. I didn't modify anything in the rear, it was all bolt in stuff. Now the front..... that's a different story!  :lol:
Offline RCCDrew
« Reply #9 on: July 06, 2015 - 05:25:41 AM »
Thanks for checking that out!
« Reply #10 on: July 06, 2015 - 09:48:24 AM »
With a '66 rear you can go with a 10" wide rim with 5" backspace to center the wheel in the well and have extra room for clearance. If you had a 68-70 housing, then you would need 5.5" backspace to center the wheel.
I have a '67 housing, 1" relocation, 10" wide rim holding a 12" wide tire. I've got room to spare on both the fender lip side and spring side.
Offline RCCDrew
« Reply #11 on: July 06, 2015 - 12:32:45 PM »
What metric size are the tires? Do you have pics?
« Reply #12 on: July 06, 2015 - 03:02:02 PM »
They are MT SR 26x12x15, so roughly a 305-45rx15.
Offline KillerBee
« Reply #13 on: July 13, 2015 - 04:16:15 PM »
For those who installed a B body rear under a Challenger did you have to cut/modify the rear valance to clear the rear spring hanger?
Anyone reuse the original rear sway bar? How did you modify it?
I'm going to install a B body Dana under my wife's 71 R/T Challenger to try and get those rear 10" centerlines under the car.
« Last Edit: July 13, 2015 - 04:26:36 PM by KillerBee »
« Reply #14 on: July 13, 2015 - 04:32:50 PM »
Nope didn't touch a thing , it was all a bolt in deal. As for the rear sway bar I have the Hotchkis rear bar so it fit with no issues at all ( it bolts on the housing. )
