Author Topic: Ammeter twitch  (Read 5979 times)
Offline sadil340
Ammeter twitch
« on: July 03, 2015 - 09:53:46 AM »
My ammeter twitches slightly. Charge rate seems good, it's just the twitching that has me asking the question. Is it more likely to be from the voltage regulator or the alternator? Is there any way to test to isolate the cause?
Thanks!
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline 73_Cuda_4_Me
Re: Ammeter twitch
« Reply #1 on: July 03, 2015 - 04:49:16 PM »
With car sitting still? Any accessories on (like radio/amp)?
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline sadil340
Re: Ammeter twitch
« Reply #2 on: July 04, 2015 - 02:41:03 PM »
I noticed it while driving. I'll see if it does it while idling and will meter the alternator.
3:55 SureGrip
Owned since 1974
Offline 1 Wild R/T
Re: Ammeter twitch
« Reply #3 on: July 04, 2015 - 07:10:49 PM »
Twitching Ammeter needle is typical/normal... It's one of the many reasons why lots of cars get converted to Volt meters....   When your Ammeter twitches look at what electrical loads can be effecting the gauge... Turn signals? Brake lights? A/C clutch? Loads that stay on or off for long periods usually don't concern drivers but when you look at the gauge & it's twitching drivers get nervous... You should consider how the gauge acts compared to what electrical loads are working... Also notice when the engine idles high current loads will will cause the ammeter to read a discharge then when the engine RPMs come up the ammeter will show a high charge rate till the battery recovers it's state of charge...
Offline sadil340
Re: Ammeter twitch
« Reply #4 on: July 04, 2015 - 09:20:32 PM »
I'm comparing the behavior of the ammeter to what it used to be - pretty steady either when charging or when at full charge it didn't used to twitch. Loads don't seem to affect it at all.
3:55 SureGrip
Owned since 1974
Offline sadil340
Re: Ammeter twitch
« Reply #5 on: July 05, 2015 - 12:01:53 PM »
3:55 SureGrip
Owned since 1974
Offline sadil340
Re: Ammeter twitch
« Reply #6 on: July 06, 2015 - 06:15:01 AM »
New info: the ammeter still twitches when the car is off with the key in the run position. I disconnected the voltage regulator and took out every fuse but it won't stop. Something behind the wiper motor (maybe the wiper motor itself) is making clicking noises. Def not the alternator or regulator. Will keep trying to isolate...
« Last Edit: July 06, 2015 - 06:17:12 AM by sadil340 »
3:55 SureGrip
Owned since 1974
Re: Ammeter twitch
« Reply #7 on: July 06, 2015 - 08:05:53 AM »
 :popcorn:  curious as to what the problem is?
Offline TelisSE440
Re: Ammeter twitch
« Reply #8 on: July 06, 2015 - 01:03:58 PM »
The wiper motor does need continuous current for it to work in any position. If you're hearing clicking sounds then disconnect it from the firewall bulkhead connector and watch it. As Wild R/T says, there has to be a device that uses momentarily the current like a turn signal, or could be a loose electrical connection, which happen in wiper motors...
Offline sadil340
Re: Ammeter twitch - solved!
« Reply #9 on: July 06, 2015 - 03:58:23 PM »
Just logged in to report the mystery solved when I see that ChallengerSE nailed it. The wiper motor is making the noise and drawing the current. Strange as it was totally restored by Jules and he was the best. Now I have to figure out what is causing the wiper motor to do this...
3:55 SureGrip
Owned since 1974
Offline roadman5312
Re: Ammeter twitch
« Reply #10 on: July 06, 2015 - 04:02:04 PM »
Does the wipers work correctly ? Do they park correctly ?  Maybe the wiper arms are not adjusted properly and the motor is constantly trying to park.  :dunno:  Just a thought.
Offline TelisSE440
« Reply #11 on: July 06, 2015 - 04:07:26 PM »
 :2thumbs: Actually you helped with what you told us.
Offline dutch
Re: Ammeter twitch
« Reply #12 on: July 06, 2015 - 06:30:38 PM »
the only thing I can think of that would be able to make the wiper motor click, would be the park switch mechanism on the reverse of the switch plate .   They get snatched down by the gear latch or bumped up.  I could imagine it touching just a bit  :dunno:
To check, just remove 5 screws and turn the switch plate over and see if the long flipper is sitting on top of the shorter flat. Do mark the position of the plate before removal...
*** Bart ***
Offline sadil340
Re: Ammeter twitch
« Reply #13 on: July 07, 2015 - 07:32:35 AM »
Excellent suggestion Bart, I will do that today.
The wipers are not fully retracting and need help. When I push them down into the resting position I hear a click and assumed that meant the solenoid was accepting the correct position. I will be curious to see what's going on behind the plate.
« Last Edit: July 07, 2015 - 07:35:09 AM by sadil340 »
3:55 SureGrip
Owned since 1974
Offline 1 Wild R/T
Re: Ammeter twitch
« Reply #14 on: July 07, 2015 - 01:07:41 PM »
Clocking the park is how you set the park position so the fact the wipers don't fully park could mean the plate is slightly out of position...   Good catch....
