Author Topic: Ammeter twitch  (Read 5977 times)
Offline TelisSE440
Re: Ammeter twitch
« Reply #15 on: July 08, 2015 - 04:04:54 AM »
You 'll have to disconnect the wiper arm rod from the wiper motor. Then you check if it works at all speed and then close it off to see if it parks correctly and with NO movement or noise afterwards. If the noise comes when the parking ends, then you disconnect the plate and watch at how the breakers on the plate engage and disengage when the plastic camshaft moves it.
Offline solarguy
Re: Ammeter twitch
« Reply #16 on: July 08, 2015 - 09:26:00 AM »
Check that the grounding strap on the motor has a good ground and also the same for the switch frame in the dash.  I had issues on both Cuda's I've owned with the dash frame ground affecting wiper motor park function,  I now run a ground wire to the dash switch frame.
Offline sadil340
Re: Ammeter twitch
« Reply #17 on: July 14, 2015 - 05:15:44 PM »
Sounds like a plan, thanks!
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline sadil340
Re: Ammeter twitch
« Reply #18 on: July 14, 2015 - 05:18:12 PM »
That would be a simple fix - will give it a try
3:55 SureGrip
Owned since 1974
