Author Topic: Is my "stock" Mopar distributor up to the task?  (Read 1405 times)
Offline Grec
« on: July 03, 2015 - 03:35:58 PM »
In the middle of rebuilding my 440.
Here's the basic specs:
- Factory forged crank
- 440 Source forged h-beam connecting rods
- ICON forged pistons (-12 dish)
- 915 heads (at factory specs for now)
- Cam... not sure of, but for the purposes here, let's assume a Mopar purple cam. Maybe the 488.
- Factory Six Pack intake/carbs
- Heddman headers
- Flowmaster 3" exhaust
The question my builder has, is whether the stock type Mopar (chrome) electronic ignition/distributor will be a bottleneck for power, or will it be OK?
My goal with this build is to get around 450-500hp, while keeping a stock appearance, so I really don't want to go billet distributor/MSD route if I can help it...
Will the stock set up work for those power levels? I'm thinking yes, but would love confirmation. :-)
Thanks in advance.
P.S. I believe the coil I'm using is a Pertronix Fireball. The black, stock-looking one.
« Last Edit: July 03, 2015 - 03:37:50 PM by Grec »
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline cudabob496
Re: Is my "stock" Mopar distributor up to the task?
« Reply #1 on: July 03, 2015 - 03:54:59 PM »
I would avoid a stock Mopar distributor.
I went MSD all the way. But there are
other good systems.
2011 Kawasaki Z1000
Offline 1 Wild R/T
« Reply #2 on: July 03, 2015 - 03:55:18 PM »
Chrome box is pretty good, orange bow I'd be scrapping...   You will need to sort out the advance curve...
Offline Grec
« Reply #3 on: July 03, 2015 - 06:41:14 PM »
"You will need to sort out the advance curve..."
Yeah. That's the issue I'm dealing with, I guess.
- 440 Six Pack
« Reply #4 on: July 03, 2015 - 07:35:12 PM »
I'm just using a stock rebuilt  purchased from my local jobber. Running MSD box and a limiter kit from FBO
http://www.4secondsflat.com/Mopar%20Mechanical%20timing%20limiter%20plate.htm
« Reply #5 on: July 03, 2015 - 08:50:01 PM »
Simple answer is yes , I have done this numerous times true stock you will need to weld the slots in the advance plate to limit the curve or use the FBO limiter plate like Brad , or use the newer replacement with adjustable mechanical advance .
 I would be looking at a Lunati VooDoo cam , less duration so more vacuum which makes tuning the 6 pack easier & great power  :2cents:
Offline Grec
« Reply #6 on: July 06, 2015 - 07:04:21 PM »
Actually... I MAY have the newer one w/ mechanical advance. It's been a few years since I bought it, so not 100% sure what I have.  :biggrin:
If I DON'T, that FBO plate looks like the ticket. Thanks!
- 440 Six Pack
