Author Topic: Torsion bars set wrong?  (Read 6965 times)
Offline JKcuda
« on: July 05, 2015 - 07:19:23 PM »
So...just completed a 100% rebuild of my front and rear suspension, 4 wheel power disc kit, and new wheels to get the Cuda HOPEFULLY to Carlisle this coming weekend.  So...I just snugged up my QA1 torsion bar adjusters at first and the car sat quite nice.  Little tuck under the front fender, etc.  Now that the car is on all 4's again I torqued all the suspension components and set the adjusters to about what they were previously (I upgrade to .96 bars), and THIS is what I'm left with. :clueless:  The suspension has NO play at all in the front, it's SOLID.
My suspension was completely dropped when I put these in, but I dont think I had the adjuster arms pushed up horizontal.  Is that my problem?  I've already confirmed my bars aren't backwards so that's not it.  With the adjusters just snug the car sits great, nice travel on the suspension, but the bolts stick WAY out of the bottom of the lower control arms which is a no-go.
Any advice would be GREAT!
« Last Edit: July 05, 2015 - 07:31:23 PM by JKcuda »
Re: Torsion bars set wrong?
« Reply #1 on: July 05, 2015 - 08:04:28 PM »
The torsion bar adjusters need to be adjusted out farther to compensate for the newer bars... that's why they have adjustment, there is no set place for them... Jack it up to get the weight off the tires & back them out a half inch & see how much that helps.  Repeat till you see get what you want.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: July 05, 2015 - 08:07:50 PM »
 :iagree:  And don't forget to bounce, drive around and repeat adjustments until you get it right.  Then lock it in and go get an alignment.
Offline JKcuda
« Reply #3 on: July 05, 2015 - 08:43:01 PM »
Man am I glad to hear that!  Just seemed weird they were out so far, but I'll slowly back them out and see what happens!
Sent from my Nexus 5
« Reply #4 on: July 05, 2015 - 09:36:52 PM »
Also they will settle in a couple weeks/ month and you will need to align it again, so I've found anyhow.
Offline JKcuda
« Reply #5 on: July 05, 2015 - 09:39:57 PM »
I can handle that... The front has been weighted for about a week now so hopefully by the time I get it aligned Thursday it will have settled at least a little bit
« Reply #6 on: July 05, 2015 - 09:44:08 PM »
Do you have a sway bar? Just not on yet I assume?
Offline JKcuda
« Reply #7 on: July 05, 2015 - 09:45:51 PM »
No sway bars. Car didn't have them to begin with but I'll be adding them here eventually. Just trying to get the car on the road right now. Suspension was toast, really bad.
« Reply #8 on: July 05, 2015 - 09:47:28 PM »
Hotchkiss usually has a show special pricing at Carlisle!  :2thumbs:
Offline JKcuda
« Reply #9 on: July 05, 2015 - 09:48:56 PM »
I'll have to check it out. Gonna be looking for some other stuff too. Trunk lid, rear valence. I need to have the k member modified for a front bar right?  LCA's are qa1 so already have tabs.
« Reply #10 on: July 05, 2015 - 09:50:39 PM »
No mods to the K-Frame for a bigger sway bar.  :2thumbs:  Just need the mounting hardware/brackets, end links .
Offline JKcuda
« Reply #11 on: July 05, 2015 - 10:03:40 PM »
Bolt on then, very nice. Maybe I'll add that to my shopping list for Carlisle
Offline HP2
« Reply #12 on: July 06, 2015 - 09:52:08 AM »
The bigger the torsion bar, the less pre-load you need to crank into them, so the adjusting bolts will stick out further.
The adjuster blade not being up horizontal can also contribute to this issue. This essentially puts the adjustment one hex off from where it needs to be.
Offline JKcuda
« Reply #13 on: July 06, 2015 - 09:54:20 AM »
And that's my fear, that I'm off a hex turn. I guess we'll see this afternoon. I think I'm going to have to almost completely back out the adjuster to get it to sit right which makes me think I'll need to pull the bars and try to rotate a hex.
« Reply #14 on: July 06, 2015 - 10:09:00 AM »
If you are into the adjustment range the T bars are in right , if you were out by 60* it would not adjust at all .
 The bars are far stiffer so the adjustment bolt has to be backed out further which is OK or when the bars were made the hexs could have been clocked differently allowing the adjuster sit in the middle of the range  .
