Author Topic: ballast resistor  (Read 908 times)
Offline dana60
ballast resistor
« on: July 06, 2015 - 02:12:15 AM »
On a 1970 Barracuda with a 440 six Pac, where is the correct place for the ballast resistor to be screwed to the fire wall? Also, some are two prong and some four ? Which one is correct ? Thanks
 :wavingflag:
Offline 1 Wild R/T
Re: ballast resistor
« Reply #1 on: July 06, 2015 - 02:20:30 AM »
If you want correct you need a two prong ballast with a metal bracket, the ones with no bracket & the bolt hole through the porcelain body came out around 76... The ballast mounts beside the wiper motor, photo attached...
Offline dana60
« Reply #2 on: July 06, 2015 - 10:37:24 AM »
So this set up is incorrect ?
Offline 1 Wild R/T
« Reply #3 on: July 06, 2015 - 11:22:57 AM »
yes, but the electronic ignition isn't sock either so how much effort do you put into a stock ballast?
Offline dana60
« Reply #4 on: July 06, 2015 - 04:24:54 PM »
Where do you get the bracket for it?
