Author Topic: Bent rear shock plate or just needs adjusting?  (Read 3811 times)
Offline FCC
  • 1973 Dodge Challenger 340
« on: July 06, 2015 - 11:53:44 AM »
I just replaced my old shocks with Bilstein RCD shocks.  I had a difficult time putting on the rear passenger side because the lower shock mount bolt wasn't straight on. I didn't have this problem with the driver's side.  I cannot tell if the shock plate is bent or if I just need to adjust it???  If so, what is the best way to adjust?  I haven't touched it but thought the plate squares up against the bottom of the leaf springs so what would there be to adjust?  Any help will be greatly appreciated.  Thanks.
Re: Bent rear shock plate or just needs adjusting?
« Reply #1 on: July 06, 2015 - 11:58:51 AM »
You might try removing the shock and a big adjustable and a little heat? It does appear to be bent?
Offline CudamanTom
« Reply #2 on: July 06, 2015 - 12:52:17 PM »
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline TelisSE440
« Reply #3 on: July 06, 2015 - 01:07:10 PM »
Offline js29no
« Reply #4 on: July 06, 2015 - 02:40:57 PM »
ya  i see it to! someone probable put a jack in the wrong spot, :clueless:
Offline roadman5312
« Reply #5 on: July 06, 2015 - 03:19:52 PM »
    You could pull the shock off, slide a piece of pipe over the stud and try to bend it back up if you don't have a torch to heat it. Left as is it will eat the shock bushing quickly.
Offline Katfish
  • 70 Challenger
« Reply #6 on: July 06, 2015 - 04:20:07 PM »
Since it needs to come up, what about putting a jack under the edge and tweak it as needed?
Offline dutch
« Reply #7 on: July 06, 2015 - 06:12:32 PM »
euh... looks to me the stud is not the problem and you will not be able to get that metal back in shape using the stud for leverage...it will just kill the stud.
IMO there are 2 ways to get it back into shape. Heat it and beat it till it looks ok. ( risk of fire, hitting other arts of the car, probably hurt a finger or two...)  or take it off the car and heat it ,clamped into vise or use an anvil to get it back into shape .
*** Bart ***
Offline crash340
« Reply #8 on: July 06, 2015 - 06:12:53 PM »
The stud is not bent, its the plate that is bent, dont bend or try to straighten the stud, take the plate off, give it some good heat and try and bend it back, the piece that the stud is fitted to should be verticle.
Greg
73 Cuda
Brisbane, Australia
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #9 on: July 06, 2015 - 08:31:54 PM »
Or get another plate off someone's parted out cuda.   Simple correct low cost. :bigsmile:
Offline FCC
« Reply #10 on: July 06, 2015 - 10:01:08 PM »
Thanks all for the feedback.  I love this forum!
I think I will try to find another one first before attempting to reshape.
Offline jimynick
« Reply #11 on: July 06, 2015 - 10:08:28 PM »
In the meantime, you could try using a 30-36" pipe wrench adjusted to just slide over the plate with a sufficient amount of meat applied to the other end. Nothing ventured and you'll know in 30 seconds if it's going to move for you. A cheater piece of pipe ( I use my floor jack handle) can also help. Good luck and keep the really BFH handy!  :cheers:
Offline CudamanTom
« Reply #12 on: July 07, 2015 - 07:13:33 AM »
I think this would be a good move here.
Offline CUDA JAS
  • vroooooom!
« Reply #13 on: July 07, 2015 - 08:39:14 AM »
I am with him! Correct way would be to replace it!!
I think you can even buy them new.  But there are also enough guys parting out these cars that you can find a used one!
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #14 on: July 07, 2015 - 09:51:18 AM »
Keep in mind that 70's are a little different in size, they are slightly shorter than 71-74...
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
