Author Topic: 528 HEMI Rotating Assembly And Solid Roller Camshaft Out Of The BEAST...  (Read 5119 times)
Offline Oldschool
  • Member Since 9-05-06
These are the parts that came out of the 528 HEMI in the beast. They are for sale.....  I only took a pic of 2 pistons, but they are a set of 8.  The flexplate doesn't go with the crankshaft. I used the flexplate to help the crank stand up for the photo. The rotating assembly is already balanced and the pistons are 10.5 compression - pump gas friendly.  Cam is a custom grind solid roller. I can get the cams specs if anyone is interested and the exact cylinder bore sizes that the pistons were in. 4-1/2" bore. I also have 2 Holley 750 HP carbs that came off the car.  I will take $1500.00 for all of it  -- plus shipping. I am just north of Atlanta Georgia.... :2thumbs:
Ken  --  In Georgia
Offline Super326
Is that a bolt in ? Meaning no mods to an otherwise stock factory block?
Offline Oldschool
As far I as I know, the only mod needed is that you might need to bend/alter the oil pick up tube a little bit to clear the crank. I can get the exact cylinder bore specs if you want.
Ken  --  In Georgia
Offline Oldschool
Re: 528 HEMI Rotating Assembly And Solid Roller Camshaft Out Of The BEAST...
« Reply #3 on: August 06, 2015 - 09:45:39 AM »
These are the carbs that are for sale. Both are Holley part# HLY-0-80528-1. They currently list new in the Summit catalog for $789.95 each.  They are in the deal with the rotating assembly for the $1500.00 price. As you can see, the carbs are $1600.00 alone......
Ken  --  In Georgia
Offline Super326
« Reply #4 on: September 21, 2015 - 07:24:43 PM »
Let's talk.......
Offline rUNCHARGER
« Reply #5 on: September 21, 2015 - 08:46:47 PM »
I might be interested in the camshaft. This is a stupid, crazy, good deal in case no one knows it BTW.
Sheldon
Offline Super326
« Reply #6 on: September 22, 2015 - 12:29:34 AM »
 :wavingflag:
Hey Oldschool do you still have the parts ?
Offline Oldschool
« Reply #7 on: September 22, 2015 - 07:52:23 AM »
Everything is still available. I have not posted or advertised this stuff anywhere but here, so it's not like the whole world knows about it... :grinno:  This is a private sale just for "us"....   :grinyes:
Ken  --  In Georgia
Offline Super326
« Reply #8 on: September 23, 2015 - 09:37:42 AM »
 :wavingflag:
I also need 426 2x4 intake , vavle cover black , dist. , valley pan , 15" Magnum 500 wheels , and Hemii Shaker Scoop system
Offline rUNCHARGER
« Reply #9 on: December 03, 2015 - 11:06:09 PM »
Did you sell this stuff yet? If not I am interested in the camshaft if you could supply the specs?
Thanks
Sheldon
Offline Oldschool
« Reply #10 on: December 04, 2015 - 08:04:46 AM »
Thanks
Sheldon
I still have it. I will look up the spec card this weekend and post it up for you...
Ken  --  In Georgia
Offline rUNCHARGER
« Reply #11 on: December 04, 2015 - 12:03:17 PM »
Thanks: I'm about to put my 528 back together and was going to use another solid camshaft but would rather go to a roller I think. I have one but it's an old 290-700 lift Crane and I don't think it will be very streetable.
Sheldon
Offline Oldschool
« Reply #12 on: December 04, 2015 - 12:18:04 PM »
Not sure if you have ever heard the cam when it was in the 528" Hemi or not, but you can see it and hear it here:  My car is about 2 minutes into the video. We were playing around one morning before work...     :grinyes:   :burnout:
http://www.cuda-challenger.com/cc/index.php?topic=36066.0
 :cheers:
Ken  --  In Georgia
Offline Oldschool
« Reply #13 on: December 05, 2015 - 06:19:31 PM »
I located the Cam Card.  If you decide to buy the camshaft, I will send you the spec card with the cam.  Here are the numbers as they are listed on the card.
Valve Adjustment  ---Intake - .026       Exhaust - .026
Gross Valve Lift  --  Intake - .637         Exhaust - .617
Duration @ .020   --   Intake - 300*      Exhaust - 296*
Valve Timing @ .050:    Intake Open  --  24* BTDC         Intake Close  --  64  ABDC
                                     Exhaust Open -- 62* BBDC         Exhaust Close  --  22* ATDC
These specs are for cam installed at 110* Intake Center line.
Duration @ .050   ---   Intake - 268*     Exhaust - 264*
Camshaft Lobe lift  --  Intake - .4060     Exhaust - .4060
Lobe Separation  110.0
Hope  this helps....    :2thumbs:
Ken
Ken  --  In Georgia
Offline rUNCHARGER
« Reply #14 on: December 05, 2015 - 07:48:32 PM »
I sent a PM, Thanks.
Sheldon
