Author Topic: heat/defrost cables?  (Read 762 times)
Offline JoeGrapes
« on: July 07, 2015 - 08:51:30 AM »
on a non air car where do the heat/defrost and temp cables run? Do they go thru the space above the steering column bracket and below the bracket that's welded to the cowl that the steering column bracket is bolted to?  Wow that was a mouth full. I've looked at a factory diagram and it's not really clear.
Re: heat/defrost cables?
« Reply #1 on: July 07, 2015 - 09:56:59 AM »
Yes, that's where they go...
Offline JoeGrapes
« Reply #2 on: July 07, 2015 - 10:59:17 AM »
Ok, thanks burdar.
