Author Topic: Car won't start, buyer on the way! Help!  (Read 6606 times)
Offline mopar jack
Re: Car won't start, buyer on the way! Help!
« Reply #15 on: July 13, 2015 - 10:55:53 AM »
I always carry a small jumper wire with alligator clips. You can connect one end to positive on battery and the other to the coil positive. This will assure full voltage to coil and when you crank the starter it should fire if not you have a points/pick-up or ecu problem if it's electrical.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #16 on: July 13, 2015 - 11:27:06 AM »
Check the air gap on the reluctor/pick up coil.. Should be .008 check with a brass feeler gauge...
Would they effect the spark coming from the blaster coil?
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #17 on: July 13, 2015 - 11:27:42 AM »
Thanks I'll try that
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline 1 Wild R/T
« Reply #18 on: July 13, 2015 - 12:21:55 PM »
The pickup coil in the distributor is where the spark signal comes from... No signal=No spark...  If the air gap is above .012 you'll get intermittent signal, above .020 no spark at all....
« Reply #19 on: July 13, 2015 - 06:27:27 PM »
Doesn't matter what the coil is. The pick-up/reluctor sends the signal to the ECU to control when the coil generates HV to the spark plug.  :2cents:
Offline 750-h2
« Reply #20 on: July 16, 2015 - 02:33:06 PM »
Did you ever find the problem?
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #21 on: July 16, 2015 - 03:33:16 PM »
Haven't been able to get to the car the last 2 days, I got a better offer on the car and from a Texas buyer who has sent me a deposit, he will pick it up on his way to sturgis at the end of the month. So the car not starting that day worked in my favor Hahaha
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
« Reply #22 on: July 16, 2015 - 04:31:40 PM »
If he doesn't want the seats....... :wave:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #23 on: July 16, 2015 - 05:17:35 PM »
You got it brad
« Last Edit: July 16, 2015 - 10:23:47 PM by moparman82 »
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline Kapteenikosmos
« Reply #24 on: July 16, 2015 - 05:45:52 PM »
I have had some problems with the reluctor also with new mopar perf distributor. The metal tab holding the pickup coil was slightly kinked when bought and that caused uneven or tapering air gap between the pickup and the reluctor. I had to set the air gap so that it was just shy of touching the reluctor wheel when the small amount of slack was taken into account. I did straighten the metal tab and now it is not that picky anymore but my setup is still closer than the 0.008.
My symptoms when pickup needed adjustment was no start with just some occassional pops. First time the problem came, the car ran fine on the day before and did not start on next morning.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #25 on: July 16, 2015 - 11:40:43 PM »
You got it brad
Those seats will be making their way around the country.....
