Author Topic: Dr Diff Brake Instruction  (Read 860 times)
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« on: July 12, 2015 - 04:21:20 PM »
Anyone have instructions or a pick of how the front calipers are installed in a Dr Diff brake kit?
Offline HP_Cuda
  • Mopar or No Car!
Re: Dr Diff Brake Instruction
« Reply #1 on: July 13, 2015 - 12:46:27 PM »
The 70's Ebodies have the calipers mounted in the front.
Sway bars affect installation:
    Install calipers facing the front on all E-Bodies.
    Install calipers facing the front on A-bodies equipped with aftermarket sway bars, no sway bars or '73 and newer factory sway bars.
    Install calipers facing the front on B-bodies equipped with aftermarket sway bars, no sway bars or '70 and newer factory sway bars.
    Install calipers facing the rear on '72 and older A-bodies equipped with factory sway bar.
    Install calipers facing the rear on '69 and older B-bodies equipped with factory sway bar.
Offline dfrazz
« Reply #2 on: July 13, 2015 - 04:05:28 PM »
Thanks HP - got a hold of Cass and he said I had the calipers assembled correctly except the bleeder needs to be on top so I had to flip them.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: July 14, 2015 - 02:20:33 PM »
 :2thumbs:
I'll be doing my shortly as well, gotta go grab some new upper ball joints.
 :working:
