Author Topic: Loose Steering  (Read 3090 times)
Offline cudabob496
Loose Steering
« on: July 13, 2015 - 05:45:35 PM »
Think its been about 30 yrs since any suspenion upgrades.
The manual steering is pretty loose.  Without rebuilding the steering
box, which components should I replace? thanks
2011 Kawasaki Z1000
Offline dutch
Re: Loose Steering
« Reply #1 on: July 13, 2015 - 06:11:01 PM »
after 30 yrs...?   I`d say everything between horn button and wheel hub  :2cents:
*** Bart ***
Offline cudabob496
Re: Loose Steering
« Reply #2 on: July 13, 2015 - 07:39:00 PM »
ok, maybe 25 years, but its just a straight line street racer for the most part,
and, everything else has pretty much been replaced.
2011 Kawasaki Z1000
Re: Loose Steering
« Reply #3 on: July 13, 2015 - 09:17:43 PM »
Have you given any attention to the sector shaft adjustment screw?
Offline cudabob496
Re: Loose Steering
« Reply #4 on: July 13, 2015 - 10:11:23 PM »
don't know what that is, but will research it.  Seems the steering wheel turns more degrees to the left,
before the tires turn, than when steering to the right.
2011 Kawasaki Z1000
Offline cudabob496
2011 Kawasaki Z1000
Offline DAYLEY/CHALLENGER
Re: Loose Steering
« Reply #6 on: July 13, 2015 - 10:34:42 PM »
Looks good from my house.   Mine needs adjusting too.  Did not realize the hard spot in center.  I don't have it, now I know I need to be close to it.  Good information.
Dave or David
Re: Loose Steering
« Reply #7 on: July 13, 2015 - 10:44:34 PM »
so, does this guy have it right?
http://www.bing.com/videos/search?q=mopar+sector+shaft+adjustment+screw&qpvt=mopar+sector+shaft+adjustment+screw&FORM=VDRE#view=detail&mid=B7DA7030E7168BAB3087B7DA7030E7168BAB3087
Gives you the idea... not necessary to take the thing apart for adjustment, just loosen the jamb nut. There's a process Ive seen posted here somewhere for a simple adjustment.
Re: Loose Steering
« Reply #8 on: July 13, 2015 - 10:50:30 PM »
Offline cudabob496
Re: Loose Steering
« Reply #9 on: July 14, 2015 - 12:34:56 AM »
Probably just adjust nut, so steering is most responsive (without slop), with no hangups from
full left poistion to full right steering wheel position.
Question is: Does front suspension have to be under load while doing the adjustment??
2011 Kawasaki Z1000
Re: Loose Steering
« Reply #10 on: July 14, 2015 - 12:40:23 AM »
Everything I've seen suggests disconnecting the pitman arm no load seems to be the way to go.
Offline cudabob496
Re: Loose Steering
« Reply #11 on: July 14, 2015 - 02:16:50 AM »
so, wheels on the ground??
2011 Kawasaki Z1000
Offline cudabob496
Re: Loose Steering
« Reply #12 on: July 14, 2015 - 03:46:02 AM »
my 72 service manual calls it the cross-shaft adjustment screw, and
has about 3 paragraphs on how to adjust it.
2011 Kawasaki Z1000
