Author Topic: Car frame caster  (Read 3266 times)
Offline mauls
Car frame caster
« on: July 15, 2015 - 12:40:53 PM »
I know these cars are uni bodies but i was curious if anyone had some Idea's for me to weld up a caster to move my car around without the K member on it.
I was thinking of using some square tubing and bolt it right to the original bumper bracket holes, and then weld another square tube attached to a caster to that.
Thoughts?  Idea's?
Thanks!
Kansas City, MO
1970 Challenger &2010 Challenger SRT8 six speed
Offline anlauto
Re: Car frame caster
« Reply #1 on: July 15, 2015 - 12:43:56 PM »
US Car Tool sells a kit you can copy. I make complete carts to move the car around.
Offline mauls
« Reply #2 on: July 15, 2015 - 12:51:57 PM »
Perfect, these should be pretty easy to make.
http://store.uscartool.com/mopar-ABE-body-front-car-moving-wheels.html
Thanks!
Kansas City, MO
Offline cordodge
« Reply #3 on: July 15, 2015 - 12:55:50 PM »
I just used some steel i had laying around and bolted it to the k-frame holes using two of the bolts and welded the wheel to the bottom, works great
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline mauls
« Reply #4 on: July 15, 2015 - 12:57:58 PM »
That looks pretty easy also, and you are just running 1 wheel in the center correct?
Kansas City, MO
Offline cordodge
« Reply #5 on: July 15, 2015 - 01:06:03 PM »
Yes one wheel, It works great and i have the rear tires on some regular 4 wheel rollers you can get fairly cheap. you could use square tubing or even some heavy angle iron
2007  Dodge Ram 4x4
Offline GoodysGotaCuda
« Reply #6 on: July 15, 2015 - 05:57:04 PM »
Here are mine, they work pretty decently. I should have gone with a heavier duty caster on the rear or move the casters in the rear further back for better weight distribution
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline dutch
« Reply #7 on: July 15, 2015 - 06:50:40 PM »
I chose to bolt it to the K-frame holes. if you don`t have a nice flat floor, those would put a lot of stress on the rails imo.
*** Bart ***
« Reply #8 on: July 15, 2015 - 07:16:19 PM »
I tied the casters together, if the rails can't handle pushing around the floor, we've got a major problem. However, without an engine and interior, I can pickup the front of the car, there isn't a lot of weight on it.
1976 Dodge Warlock
Offline AAR6BBL
« Reply #9 on: July 15, 2015 - 08:00:01 PM »
I used 8" casters, the bigger they are the easier to maneuver.
Bolted the casters to flat 1/4" plate and welded that to 2' square tubing.
Attached to bumber attachment holes up front and front of the rear spring hanger holes in back.
Works like a charm, be sure and get brakes on at least 2 0f the casters.
Greg :cheers:
« Last Edit: July 15, 2015 - 08:01:58 PM by AAR6BBL »
"There's no such thing as putting a '70 AAR 'Cuda exactly where you want it. The 'Cuda isn't interested in such things, for they require finesse. Finesse asked the 'Cuda out to dinner once, but the 'Cuda stood it up to go drink beer under an overpass with her hot little sister. As far as this car is concerned, finesse can go stuff itself."
Offline twalker
« Reply #10 on: July 15, 2015 - 09:31:55 PM »
Here's what I did, works great
Better photos at home but anyway, 1 inch square tubing to 6" castors
