Author Topic: E Body Leaf Spring Replacement  (Read 1304 times)
Offline annularnos
« on: July 15, 2015 - 03:28:50 PM »
How big a job is it to change leaf springs on an E body without a lift? It looks like one would have pretty good access after jacking the rear and removing the rear wheels/tires and valance. None of my bolts/nuts should be frozen, so it looks like everything should come apart fairly easily. My plan is to chock the front tires and jack the rear until I can get jack stands under the frame by the forward leaf spring hanger access. Then remove the jack and use it to raise the axle assembly to unload the springs. Any tips appreciated.
Offline TonyBolton
Re: E Body Leaf Spring Replacement
« Reply #1 on: July 15, 2015 - 03:31:20 PM »
3 jack stands and a jack.....i didnt even remove the wheels.
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: July 15, 2015 - 04:32:15 PM »
I did the same last winter.  Not hard at all.  Just make sure you take of the rear valence!!
And the third jack stand goes under the pinion to prevent it form rotating forward once you loosen the leaf springs!!
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline TonyBolton
« Reply #3 on: July 15, 2015 - 04:34:02 PM »
I jus did one leaf at a time....no fear of rotation.
3rd jack stand under one axle tube. ....jack under other to regulate lift/drop.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #4 on: July 15, 2015 - 04:40:22 PM »
Jason
Don't forget to block the wheels!
