Author Topic: Shocks to use with Super Stock Springs  (Read 3013 times)
Offline Icarus38376
« on: July 16, 2015 - 07:46:59 PM »
Hey Guys, I need longer shocks for an e Body due to SS springs.  When I check Rock Auto it seems that the C body shocks that were suggested are the same part number as the e body shocks.  Any idea on which shocks will work?
Thanks
Offline msbaugh
Re: Shocks to use with Super Stock Springs
« Reply #1 on: July 16, 2015 - 07:49:51 PM »
I always measure compressed and extended lengths and just call around until I get numbers from the seller  :2cents:
« Reply #2 on: July 17, 2015 - 12:03:25 AM »
Maybe Imperial ?
« Reply #3 on: July 17, 2015 - 09:07:04 AM »
 :iagree:   QA1 wanted these measurements before they would suggest a part # . Mine is lower than stock so the stock part # wouldn't work.
« Reply #4 on: July 17, 2015 - 09:19:03 AM »
1/2 ton truck.
Offline daveh
« Reply #5 on: July 17, 2015 - 10:54:03 AM »
This is going to sound funny but I encountered the same issue a few years ago and discovered that shocks from a mid 70's truck worked perfectly.  I got them from my local Napa store.  Good luck.
Offline Icarus38376
« Reply #6 on: July 17, 2015 - 11:02:18 AM »
Thanks guys, just ordered a set for a 74 Dodge D100 pickup.  Let's see what happens.   :crazy:
Offline TonyBolton
« Reply #7 on: July 17, 2015 - 12:24:41 PM »
....or just buy the mopar specific shocks for the SS springs and be done with it. ;)
Offline Icarus38376
« Reply #8 on: July 17, 2015 - 01:43:09 PM »
Where do I find these mopar specific shocks?
Offline TonyBolton
« Last Edit: July 17, 2015 - 02:01:08 PM by TonyBolton »
Offline Icarus38376
« Reply #10 on: July 17, 2015 - 02:05:41 PM »
Thanks Tony, I saw those, but they said A-Body so I moved on...I could not find any length specifications either.  I think the truck shocks will work, plus they are old school yellow  :bigsmile:
Offline TonyBolton
« Reply #11 on: July 17, 2015 - 02:12:30 PM »
They worked but those springs are pretty dang stiff so it may just be me not being a drag race guy but I certainly did not like the ride at all with them.
I mean the few times I took it to the drag strip it did great with ****ty tires but it's just not the way I like to ride.
Also if you want to go on the cheap route you can just buy some two or so inch shock extensions ....my dad used those before he put the shocks on.
Offline vinb
« Reply #12 on: July 17, 2015 - 10:59:44 PM »
QA1's  adjustable or Rancho's RS5000, check your measurements on the Rancho's
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: July 20, 2015 - 04:12:30 PM »
I have a pair of Ranchos I pulled off one of my cars.
PM me if you are interested.
B
