Author Topic: Pulling engine, how to support trans.  (Read 6603 times)
Offline 74 challenge
« on: July 19, 2015 - 06:12:54 PM »
Hi guys,
I'm pulling my tired 318 for a 360 and since this is a fairly easy swap I'm going to pull it through the hood and no go underneath.
Does anyone have a great idea of how to support the trans while the engine is out if the car? I assume someone has an idea here before I mock something up.
I want to pretty up my engine bay while there is no engine in there so it will be a good amount of time till it goes back in there.
1-8-4-3-6-5-7-2
Offline johannes
Re: Pulling engine, how to support trans.
« Reply #1 on: July 19, 2015 - 06:22:59 PM »
I used a sissor-jack during dismount...
Then a metal rod under the trans connected to the torsion bars using exhaust clamps...which allows you to move the car...
Offline GoodysGotaCuda
« Reply #2 on: July 19, 2015 - 06:27:13 PM »
Ratchet strap between the frame rails.  :icon16:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline rUNCHARGER
« Reply #3 on: July 19, 2015 - 08:14:37 PM »
yes, ratchet strap.
Sheldon
« Reply #4 on: July 20, 2015 - 07:20:00 AM »
Alright thanks guys, looks like I need a ratchet strap.
1-8-4-3-6-5-7-2
Offline loco340cuda
« Reply #5 on: July 20, 2015 - 12:20:22 PM »
Agreed, ratchet strap.  I have personally done this with success.
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
« Reply #6 on: July 20, 2015 - 12:42:47 PM »
Just some long bolts through the bell housing and a 2x4 across the frame rails.
Offline YellowThumper
  • I left the snow for this?
« Reply #7 on: July 20, 2015 - 05:11:10 PM »
Don't neglect the counterbalance difference between the 318 and 360.
« Reply #8 on: July 21, 2015 - 07:56:22 AM »
Want to elaborate on this?
1-8-4-3-6-5-7-2
« Reply #9 on: July 21, 2015 - 10:43:42 AM »
A 360 is balanced differently then a 318.  The 360 has a weighted balancer at the front of the engine and uses a weighted torque converter at the back.  In order to use the 318 torque converter, you need a weighted flex plate designed for the 360.
« Reply #10 on: July 21, 2015 - 10:54:19 AM »
318/340 engines are internally counterbalanced at the crank. 360s are externally counterbalanced. You will need correct harmonic balancer and I believe also correct balanced flywheel.
« Reply #11 on: July 21, 2015 - 03:42:14 PM »
The harmonic balencer is on the engine already.
I need to research the other two. Does it matter that the block is a 72?
1-8-4-3-6-5-7-2
« Reply #12 on: July 21, 2015 - 04:14:26 PM »
Look for a B&M weighted flexplate for a 360/904.  I assume the 318 had a 904 behind it that you are still going to use?
Compare the balancer from the 318 and the 360.  You'll see that there is a large weight on the 360 balancer.
« Reply #14 on: July 22, 2015 - 09:01:40 AM »
So if I run this flex plate I can run my stock 904 converter and I require no more parts for the swap. How does this plate bolt up? Between the flywheel and the converter?
1-8-4-3-6-5-7-2
