Author Topic: Those with Year One 17" Rallyes  (Read 1770 times)
Offline Bucks70RT
« on: July 20, 2015 - 04:38:27 PM »
What brakes are you using with these wheels?
Offline challenger_affair
Re: Those with Year One 17" Rallyes
« Reply #1 on: July 29, 2015 - 01:49:26 AM »
I currently have drum brakes all around but I'm hoping to upgrade the front to disk using the Viper kit from Dr. Diff.  I notice its currently out of stock, hopefully this isn't gone permanently!  He seemed to think it would fit when I talked to him a while ago but at the time I don't think it had been tested.  I'd be curious to know if anyone has successfully used that setup...
1970 Challenger 383 RT Auto Plum Crazy
Offline anlauto
« Reply #2 on: July 29, 2015 - 07:18:55 AM »
I've used them with 12.90" Wilwood brakes all around
Offline Bucks70RT
« Reply #3 on: August 02, 2015 - 11:17:08 AM »
Can you give me some info on the Wilwoods?
Offline anlauto
Offline 7212Mopar
« Reply #5 on: August 02, 2015 - 11:57:53 AM »
I read the Wilwood rear disc requires green axle bearings. Anyone try Bear?
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline anlauto
« Reply #6 on: August 02, 2015 - 01:23:50 PM »
Willwood require green bearings with a snap ring :2thumbs:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #7 on: August 02, 2015 - 05:49:55 PM »
So does the Right Stuff.
« Reply #8 on: August 02, 2015 - 11:38:59 PM »
DrDiff rear brake kits use stock tapered bearings.  :2cents:
