Author Topic: Gear ratio question  (Read 1970 times)
Offline Barry Stewart
Gear ratio question
« on: July 20, 2015 - 09:34:33 PM »
Hey a newbie here. I have a 70 Cuda 440-6. I have a Dana with 3.54. I just put drag radials on and I'm looking for more " throw you back in the seat" feeling but I still want to do some 30 to 50 miles drives at 55-65. What's my best choice for gearing ? 3.90, 4.10? Tell me your thoughts, thanks
Offline ToxicWolf
Re: Gear ratio question
« Reply #1 on: July 20, 2015 - 09:45:47 PM »
I used 3.73 because I have a 5-speed and didn't want it lagging at slow highway speeds.  What kind of transmission and do you know its gearing?
« Reply #2 on: July 20, 2015 - 09:46:13 PM »
This will help you figure your RPM's  at given speeds with different gear ratio's
http://vexer.com/automotive-tools/speed-rpm-calculator
Lots of factors to consider, cam power band, tire diameter, convertor slippage if it's an automatic.
« Reply #3 on: July 21, 2015 - 03:21:21 PM »
I have a 727 built by CRT Super Street with a TCI Street Fighter converter. Tires are 28" tall. Purple shaft cam, not sure of left etc. would going from 3:54 to 3.73 make much difference? I know 4.10 is pushing it for what I do.
« Reply #4 on: July 21, 2015 - 03:33:36 PM »
RPM wise about 200 rpm more @ 60 mph
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: July 21, 2015 - 03:47:48 PM »
You will be pulling > 3k with that setup and over long hauls would get really annoying.
Ever thought of getting an OverDrive? Then you can step up to lower gears like 3.73, 3.91.
« Reply #6 on: July 21, 2015 - 05:31:28 PM »
I would love an overdrive or a tremic 5 speed but not in the budget
Offline gafletch
« Reply #7 on: July 22, 2015 - 10:10:17 AM »
Brad, according to the reference, going from a 410 to a 355 would only reduce my rpm a few hundred at 65 mph. May not be worth the expense to change.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: July 22, 2015 - 12:28:24 PM »
With a 275-60-15 rear tire and going from 3.55 to 4.10 you are going to see an increase of 400 rpm and almost 500rpm.
Heck with the 3.55's with that tire you are doing 3k at 70mph freeway speeds. Can get a bit annoying over long hauls.
Offline vinb
« Reply #9 on: July 24, 2015 - 06:53:06 PM »
I have a 3.55 with a 275/60/15  89" round tire actual rpm is 2850 at 65 mph with the 4spd.   Automatic may see 200 rpm higher.
