Author Topic: Do I have the proper transmission crossmember for my 1970 Challenger??  (Read 941 times)
Offline 750-h2
Car is out of town at the body shop so I cannot measure. Found this cross member in my parts and want to detail it but I am not sure it is the correct one. There is one on Ebay right now that the seller claims is for a 70/71 E body, while it looks the same as mine the spacing between the mounting bolt holes is different. :dunno:
Here are the measurements of mine.
-overall length 19 1/4"
-center to center of outer mounting holes 18"
-center to center of inner mounting holes 8 1/2"
I have also included some pictures. Any help would be greatly appreciated! :cheers:
Offline anlauto
Yours looks correct....If the holes are wider looking then the one on EBay, then yours is correct and he's wrong on his description :2cents:
Offline 750-h2
Thanks Al, but just to be 100% sure any chance that you can measure Brian Dougon's old one for me?
Offline anlauto
Okay, I measured Brian's and it measures the same as yours, 8 1/2" and 18"
Offline 750-h2
Perfect! Thanks again for the help. :2thumbs:
