Author Topic: Front Sway Bar installed correctly??  (Read 1519 times)
Offline cudabob496
« on: July 23, 2015 - 01:36:38 AM »
Not sure if my front sway bar on 72 cuda is upsidedown or not. The ends (last 3 inches)presently turn up slightly
to attach to the end links. But bar can also be installed with the ends turned down slightly.
2011 Kawasaki Z1000
Offline crash340
Re: Front Sway Bar installed correctly??
« Reply #1 on: July 23, 2015 - 04:46:45 AM »
I believe the ends should turn down slightly from memory
Greg
73 Cuda
Brisbane, Australia
Offline anlauto
« Reply #2 on: July 23, 2015 - 07:26:37 AM »
When looking at it from the side it should be frowning NOT smiling  :bigsmile:
Offline cudabob496
« Reply #3 on: July 23, 2015 - 01:46:15 PM »
yes, the 12 inch end length on each side should be angled down about 20 or 30 degrees,
but I mean the last 2 or 3 inches of each end?
2011 Kawasaki Z1000
Offline crash340
« Reply #4 on: July 23, 2015 - 02:41:11 PM »
CB, the very ends of the rod should point down, not up
Greg
73 Cuda
Brisbane, Australia
Offline cudabob496
« Reply #5 on: July 23, 2015 - 04:32:10 PM »
ok, thanks, crap, gotta make it right!
2011 Kawasaki Z1000
Offline 70 GRAN CPE
« Reply #6 on: August 09, 2015 - 01:37:27 AM »
Frowning not Smiling is correct , perfect and easy way to understand how sway bar mounts, Good answer anlauto.
Offline twalker
« Reply #7 on: August 09, 2015 - 09:23:05 AM »
Thanks guys, this just helped me out too
Sent from my iPad using Tapatalk
