Author Topic: 71 'Cuda restoration project  (Read 18704 times)
Offline HemiTunis
Re: 71 'Cuda restoration project
« Reply #30 on: September 14, 2016 - 04:28:52 PM »
 :) Yes yes, I hear you. But if we look past those and the drive train modifications, I do want it stock and I will need help getting there and I hope you and others here can help me with that.
Per from Sweden
Vehicle fleet:
1971 472 Hemi 4-speed Cuda, under restoration
The one(s) that had to go to move forward in life:
1968 Dodge Charger R/T
1970 340 4-speed Cuda, matching numbers
Offline roadman5312
« Reply #31 on: September 14, 2016 - 04:50:10 PM »
               When we built Toxicwolfs car one of our goals was to keep as much stock appearance as possible while making dramatic changes to the car. It worked out well.
Offline Amazzen
« Reply #32 on: September 14, 2016 - 05:28:16 PM »
Just like Harvey's....."Have it your way"  :drunk:
"stock" frame connectors and all :bigsmile:
Alan... they don't have "Harvey's" in the USA (or Sweden for that matter).
No one is really making mods to a rare original car... we just pretend to be doing that to get you going!  :rofl:
69 Charger R/T
69 Daytona SE
70 AAR
70 T/A
70 Charger R/T
71 GTX
71 Cuda
Offline YellowThumper
  • I left the snow for this?
« Reply #33 on: September 16, 2016 - 12:40:14 AM »
I get exactly what the point of this build is. Even though my car is a lowly 74. I care that the sheet metal remains as ma  Mopar delivered it. Magnum accessory conversion, twin turbo, twin intercoolers, custom radiator, fuel injection with electric and additional fuel return line, relocated battery, etc... All and I have only drilled a few additional small mounting holes. Great pride in that. In the back of my mind it all could come off and I would be "normal" again.
As far as frame connectors are concerned.  Their addition is a necessity in keeping the vehicle straight if it is going to be driven hard. Regardless of how they are viewed by a purist.
My2c
« Last Edit: September 16, 2016 - 12:42:22 AM by YellowThumper »
Offline HemiTunis
« Reply #34 on: September 16, 2016 - 04:31:32 AM »
Thanks YellowThumper! Yes, exactly like that! It should be reversible (without too much work) modifications.
I'm looking at Hotchkis sub frame connectors as I think they cause the least damage to the body and I like how they push the front leaf spring hanger. I will probably make something like those or buy them.
Per
Per from Sweden
Vehicle fleet:
« Reply #35 on: September 16, 2016 - 03:46:52 PM »
They are most likely what I will be installing also. Not nearly as good as full weld ones but less destructive.
Good luck.
Offline HemiTunis
« Reply #36 on: February 09, 2017 - 10:29:45 AM »
So, I did not keep this thread up to date.. Been working a lot on the Cuda and my day job and have not really had the time to update this thread. Then all the pictures I had at photobucket disappeared  :stomp:
Moved my pictures to another location and will now continue with the story. This is all before Christmas.
Cut out the sides of the quarters to be able to media blast the wheel wells and remaining structure which will not be replaced.
Then media blasted everything above the rocker panels and top of roof.
After all the media blasting I fixed the panel under the firewall on the drivers side, don't know what this is called and I don't remember what was attached to this hole? :clueless:
Start working on the damaged rocker panel, fabricating a new corner by comparing to the drivers side.
More to come...
Per from Sweden
Vehicle fleet:
Offline HemiTunis
« Reply #37 on: February 09, 2017 - 10:41:22 AM »
Still before Christmas and the cold and damp weather of south Swedish winter I continued to work towards a goal of having the body in primer before Christmas and by body I mean the sheet metal that will not be replaced.
Repaired the front frame rails on the passenger side. Before:
After:
And then a minor repair on the drivers side. Before:
After:
Then a coat of epoxi primer  :bigsmile:
More updates to follow shortly. This was still before Christmas and I have done a little more since then which is yet to be revealed.
Per from Sweden
Vehicle fleet:
Offline HemiTunis
« Reply #38 on: February 09, 2017 - 12:54:01 PM »
I disassembled the dash and had the dash pad sent for restoration as I continued to work on the body.
Test fitted the lower cowl/door hinge panels on the passenger side
And replacement firewall piece
The lower cowl pieces from AMD do not really line up as good as they should and had to be modified some, that is something that I keep encountering as I go along :(
Per from Sweden
Vehicle fleet:
Offline HemiTunis
« Reply #39 on: February 09, 2017 - 01:06:01 PM »
The time had come to spray some paint on some parts. First up were the inside of the cowl and firewall area.
Time to test fit the cowl.
When everything was looking good, I welded the firewall in place.
And finally the cowl was welded in place. It is starting to look like a car again  :jumping: :jumping:
Per from Sweden
Vehicle fleet:
Offline HemiTunis
« Reply #40 on: February 09, 2017 - 01:27:06 PM »
Took the time to media blast the dash frame before sending the dash pad to restoration. Added a couple of coats of primer to it then some black paint. Couldn't help it but I test fitted the dash frame in the car just to see some progress...
Time to do some minor rust repair on the car. Starting with the wind shield area.
Onward to the left wheel wells. Here I had to cut up the rocker panel to access the little remnants of metal left so I could recreate it.
This wasn't the easiest part to repair so far and it took several days to get it just right.
Per from Sweden
Vehicle fleet:
« Reply #41 on: February 09, 2017 - 02:08:30 PM »
Freaking awesome work. Goes to show anything can be repaired if you are willing to put in the work. This will be a great car when done and the sense of satisfaction will be off the chart.
Offline HemiTunis
« Reply #42 on: February 09, 2017 - 02:32:46 PM »
Time to start working on the doors. I removed a couple of pounds of filler from both doors and found them full of holes, some drilled and some caused by rust. I don't have a picture of the doors at this point, but they will need new skins which I have ordered.
I also bought some new hinges from AMD, both upper and lower. The lower worked perfectly with super tight movement, the upper were a different story. Look at the following pictures, how could AMD get this measurement so far off?  :stomp: :stomp:
But that was the least of my problems as I could grind the holes a little bit larger, but still annoying.
The bigger problem was with the door pushed on the hinges fully towards the body, there was still a gap of almost 1/2" to the rocker panel. And that was outwards from the body, not down to the border of the rocker.
This had me puzzled for a couple of weeks as the door lined up perfectly against the quarter panel. I have figured it out now and a little massaging of the hinge area of the body helped get the hinge further in and the lines are almost perfect!  :bigsmile:
I started working on my front fenders and removed about the same amount of filler from them as were on the doors and quarters. A lot of drilled holes in the fenders, but not much rust if any. I will try to save them as I can't afford to buy new ones and want to see if it is possible (for me)...
And finally the header panel was cleared of filler. Will work on that when the fenders are good to go. A couple of holes and dents, should be fixable if the fenders can be fixed.  :)
This is what I have been doing this week. Now the temperature has dropped down to below freezing and my air compressor is struggling. So I will wait out the cold indoors. Will start work on the fenders as soon as I have some compressed air to work with so I can start welding up the fenders.
Per from Sweden
Vehicle fleet:
Offline HemiTunis
« Reply #43 on: February 09, 2017 - 02:34:26 PM »
Thank you for the kind words 70chall440!
Per
Per from Sweden
Vehicle fleet:
« Reply #44 on: February 10, 2017 - 02:05:26 PM »
Per
Very welcome and well deserved.
