Author Topic: FBO Question  (Read 1022 times)
Offline RCCDrew
FBO Question
« on: July 25, 2015 - 09:32:41 AM »
I have a dual ballast resistor on my 73 Cuda. When installing an FBO system, are you supposed to bypass BOTH sides of the ballast resistor? I believe one side goes to coil positive and the other side goes to the ignition module.
Re: FBO Question
« Reply #1 on: July 25, 2015 - 10:13:46 AM »
You should be able to us a single / 2 pin to drop voltage to the coil as the coil will only live if you have 6-7v feeding it .
Offline RCCDrew
FBO Question
« Reply #2 on: July 25, 2015 - 10:22:22 AM »
Well.. The kit comes with a resistor bypass wire. I don't know if I'm supposed to bypass both sides or not.
Offline tman
Re: FBO Question
« Reply #3 on: July 25, 2015 - 10:51:14 AM »
bypass should be on the side that goes directly to the + side of the coil.
Offline RCCDrew
Re: FBO Question
« Reply #4 on: July 25, 2015 - 11:22:30 AM »
Ok, but should I bypass the other side too?
Re: FBO Question
« Reply #5 on: July 25, 2015 - 01:18:18 PM »
no , the green feed wire to the ecu will not have a pin to connect to on the ECU
Offline RCCDrew
Re: FBO Question
« Reply #6 on: July 25, 2015 - 01:39:04 PM »
Thanks!
