Author Topic: ride wont fire  (Read 15921 times)
Offline 1 Wild R/T
Re: ride wont fire
« Reply #45 on: July 28, 2015 - 04:36:05 PM »
Wow posting this stuff only adds to the confusion which is completely lame.
Two ballast resistors and a powerbar, plenty of better examples out there.
Jeesh!
Pardon me, I just looked through this thread & I didn't see a single post where you offered any help what so ever, never mind technical help.... Did you link a better schematic? No?? I didn't think so! If you can't bring something useful to the thread then SHUT THE HELL UP...
Offline HP_Cuda
  • Mopar or No Car!
Re: ride wont fire
« Reply #46 on: July 28, 2015 - 04:59:53 PM »
Wow this ignore feature works really well with Trolls!!!
 :smilielol: :poopoke: :roflsmiley:
Offline 1 Wild R/T
Re: ride wont fire
« Reply #47 on: July 28, 2015 - 05:26:59 PM »
And I'd say it's pretty obvious who the troll is..
Offline acudadude
Re: ride wont fire
« Reply #48 on: July 28, 2015 - 07:02:03 PM »
Cuda hunter did u make any headway with trouble shooting? Hey what year is that cuda or what your working on forgot to ask?
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: ride wont fire
« Reply #49 on: July 29, 2015 - 01:06:16 AM »
74 charger.
Still no spark.
Hope to get a chance to work on it this weekend.
Offline acudadude
Re: ride wont fire
« Reply #50 on: July 29, 2015 - 10:48:38 AM »
I think i know why it wont start.....you removed the fender tag.........put it back and it will start right up.......LOL....... :)
Offline HP_Cuda
  • Mopar or No Car!
Re: ride wont fire
« Reply #51 on: July 29, 2015 - 12:41:33 PM »
Sounds like your first hurdle to get over is to get the correct voltage to your ballast resistor while key on and start.
So check the battery cables for corrosion (i.e. resistance) and everything in between. If your ECU/Coil is known to be good you should get spark, especially if you jump it from the coil to the battery.
Offline HP_Cuda
  • Mopar or No Car!
Re: ride wont fire
« Reply #52 on: July 29, 2015 - 01:04:16 PM »
Yeah it's you.
Want some evidence?
http://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/4623942/site_id/1
Makes perfect sense now. Or you could just slink back over to mofarts.
Re: ride wont fire
« Reply #53 on: July 29, 2015 - 03:02:49 PM »
So I pushed the reset button that is on top of the interlock module and it made a definite reseting type noise inside itself.
Tried again and no start.
Despite it making reset noise, this could still be the culprit. There is one of the tabs in the socket of the interlock that you can ground to completely bypass the interlock and take it out of the equation. I'll see if I have it in my notes and post it tonight.
Re: ride wont fire
« Reply #54 on: July 29, 2015 - 08:23:32 PM »
Those two brown wires on the lower position of the relay...that position on my  '74 has been wired direct to ground. I thought the interlock was grounded directly but it isn't. I believe one of those brown wires does go to the interlock and the other goes to the transmission neuteral safety switch.
Offline ShelbyDogg
Re: ride wont fire
« Reply #55 on: August 05, 2015 - 05:50:10 PM »
If you have a tach in this car and a wire going to the coil's negative post. Try cranking with it disconnected.
Re: ride wont fire
« Reply #56 on: November 08, 2015 - 08:56:04 PM »
replaced the coil
Removed the condenser? from the positive side coil
replaced the pick up coil on distributor
hard wired the coil to battery
Have spark at plugs
Engine won't start for the life of me.
cranks and cranks.
Ran for 1 second would not repeat
took left side bank of plugs out as I figured flooding.  Not too bad.
Car wanted to start with half the plugs removed.   Didn't start it though.
Any thoughts? ?
Re: ride wont fire
« Reply #57 on: November 08, 2015 - 09:52:59 PM »
Timing can be so far off it won't fire... You put a light on it? & tipple check the plug wires are in the right order DAMHIK
« Last Edit: November 08, 2015 - 09:54:30 PM by Bullitt- »
Re: ride wont fire
« Reply #58 on: November 09, 2015 - 09:15:25 AM »
I'm at 8 before on timing.
wires are correct.
Re: ride wont fire
« Reply #59 on: November 09, 2015 - 09:17:44 AM »
Do you have cylinder pressure?
