Author Topic: Outer Steering Tie Rod  (Read 2538 times)
Offline cudabob496
« on: July 26, 2015 - 02:55:44 AM »
can the outer steering tie rod be attached above or below the steering knuckle?
On my car, the driver side has the castle nut below the steering knuckle, and its
above the steering knuckle on the passenger side, so linkage can clear headers.
2011 Kawasaki Z1000
Offline dutch
Re: Outer Steering Tie Rod
« Reply #1 on: July 26, 2015 - 04:07:15 AM »
wouldn`t think so... those have a tapered shaft/hole, don`t they...?
*** Bart ***
Offline crash340
« Reply #2 on: July 26, 2015 - 04:16:35 AM »
Yep, tapered so one way only. I believe nuts down
Greg
73 Cuda
Brisbane, Australia
Offline crash340
« Reply #3 on: July 26, 2015 - 06:45:57 AM »
correction, nuts up on the lower ball joint steering arm, down on the steering link
Greg
73 Cuda
Brisbane, Australia
Offline cudabob496
« Reply #4 on: July 26, 2015 - 02:05:12 PM »
thanks, have seen some photos where they are "nuts up"
Maybe I gotta keep my "nuts up"
2011 Kawasaki Z1000
Offline Falbz
« Reply #5 on: July 26, 2015 - 03:01:31 PM »
Offline cudabob496
« Reply #6 on: July 26, 2015 - 04:02:03 PM »
by lower, you mean closest to the wheel?
2011 Kawasaki Z1000
Offline crash340
« Reply #7 on: July 26, 2015 - 04:23:29 PM »
Yes, so the tie rod ends closest to the wheels need to be nuts up, if one of yours is nut down then when you undo the nut that tie rod end should just lift out pretty easy as the taper will be not holding it in its probably also stuffed that tie rod end and the lower ball joint steering arm
Greg
73 Cuda
Brisbane, Australia
Offline cudabob496
« Reply #8 on: July 26, 2015 - 07:53:17 PM »
ok, outer nuts on top, and inner tie rod nuts on the bottom!
thanks
2011 Kawasaki Z1000
Offline cudabob496
« Reply #9 on: July 27, 2015 - 10:32:06 PM »
A grease nipple is gonna be hard to reach, so can I grease the tie rod before installation. It does
no look like the post, on which you place the castle nut, moves within the steering arm components.
The tie rod just rotates upon itself?
2011 Kawasaki Z1000
Offline crash340
« Reply #10 on: July 27, 2015 - 10:40:17 PM »
Yeah, you can pre grease it or put in a 90deg grease nipple. If the tie rod end is near new it may not rotate, but it will when in the car
Greg
73 Cuda
Brisbane, Australia
