Author Topic: Got a vibration  (Read 774 times)
Offline blown motor
Got a vibration
« on: July 26, 2015 - 07:21:05 PM »
I've been noticing a vibration lately when I get up around 60mph. It's negligible at 50 mph. It wasn't like this last year as I recall so something is changing. I can roll the driveshaft back and forth a very small amount as if there is play in the gears. Is that normal or could it be causing the vibration. Also the vibration seems to have a bit of a drone to it. U-joints seem tight.
« Last Edit: July 26, 2015 - 07:28:14 PM by blown motor »
Re: Got a vibration
« Reply #1 on: July 26, 2015 - 07:34:34 PM »
"Some play" is normal.  Any play in and out on the pinion?
Offline blown motor
Re: Got a vibration
« Reply #2 on: July 26, 2015 - 08:42:47 PM »
Never really checked it that way. There is a 'cap' on the shaft between the U-joint and the casing. It was dry but the casing itself wasn't. I looks like it's been leaking a bit. I assume there is a seal in there.
Offline DocMel
Re: Got a vibration
« Reply #3 on: July 27, 2015 - 02:29:20 PM »
Myself and others have had the same exact symptoms.  If the u joints are GTG and the DS is in balance, then the prob most likely lies within the dif.
Our difs are 40-50 years old, and no one likes the tome/expense to have them rebuilt.  Ill say most likely thats were your prob is.  It was on mine
