Author Topic: 73 chally driver build..  (Read 34942 times)
Offline lulurocks
Re: 73 chally driver build..
« Reply #105 on: March 30, 2016 - 08:36:13 PM »
Looks great! What "led capable dimmer" did you get and why wouldn't an original switch work?
The potentiometer  style oem dimmers don't have the  smooth range of and electronic dimmer . Electronic  dimmers are solid state and are designed for LEDs .
http://www.leisurelectronics.biz/ipd-5a.html
It's not a direct swap for oem dimmers , I had the modify the output shafts and add a separate grounding circuit  and switch to turn on the dome light.
But from the front it looks like  the factory dimmer  ......
« Last Edit: March 30, 2016 - 08:41:03 PM by lulurocks »
Offline 70chall440
« Reply #106 on: March 30, 2016 - 08:43:57 PM »
where do you buy these? How much are they? I am thinking this would be good for my Speedhut gauges.
Current Mopar
Past Mopars
Offline lulurocks
« Reply #107 on: March 30, 2016 - 08:58:49 PM »
Offline 70chall440
« Reply #108 on: March 31, 2016 - 12:12:14 AM »
Thanks
Does the factory knob fit onto the shaft?
Current Mopar
Past Mopars
Offline lulurocks
« Reply #109 on: March 31, 2016 - 10:13:23 AM »
Thanks
It's not a direct swap for oem dimmers , I had the modify the output shafts and add a separate grounding circuit  and switch to have the dome light on feature  , the shaft is a full round  spline shaft , you have to mod it to a half circle to accept the factory knob
But it fits every where else great .
I put in a full cycle timer for the dome light circuit  so my dome lights and Courtist lights stay on for 15 secs  when the dome on switch is pushed ..
Offline 70chall440
« Reply #110 on: March 31, 2016 - 10:22:28 AM »
So how did you add a separate grounding circuit and switch to have the dome light on feature? I am running speedhut gauges which come with a small rotary dimmer switch. I was thinking to use the factory dimmer switch from the dome light and probably 1 or 2 instrument lights (need 1 light to illuminate the switches). My first inclination was to put the speedhut dimmer switch underneath the bezel where it would be pretty much out of sight, however if I could use this device I think it would be a nice install.
Current Mopar
Past Mopars
Offline lulurocks
« Reply #111 on: March 31, 2016 - 11:06:16 AM »
Well, on a 73 challenger the is 3  positions on the factory dimmer . Power in , power out ,  courtesy ground.
So for the. New Dimmer you  :
hook up  the 12v + in. To the in ( my case was black/y)
Hook up the 12v  + out to the  ( my case brown)
Hook nothing to the ground  terminal on new dimmer if  your new dash sockets are already grounded .....
Then the factory courtesy. Ground wires( my case the yellows)   Both get landed to one side of a new single pole momentary switch , the other side of the new switch gets a new wire to chassis ground .
Long story short.... The two yellow wires are a open ground loop , when grounded it grounds the dome light and turns it on .  That circuit contains 3 switches ( left door ,right door, dimmer ) any one of the 3 grounded will turn on the dome .
Offline 70chall440
« Reply #112 on: March 31, 2016 - 11:09:10 AM »
Thanks for the explanation, I think I am going to use this switch.
Current Mopar
Past Mopars
Offline lulurocks
« Reply #113 on: March 31, 2016 - 11:39:10 AM »
Anytime .
Offline lulurocks
« Reply #114 on: April 10, 2016 - 07:16:10 PM »
Dash done  yeah!!!
90%'of vintage air in , outside door handles in,  latches and strikes done, door and quarter glass in , Dynamat done.
Dynamat done:
Vintage air:
« Last Edit: April 10, 2016 - 07:23:52 PM by lulurocks »
Offline roadman5312
« Reply #115 on: April 10, 2016 - 07:46:35 PM »
                 Nice   :2thumbs:      :rebel:
Offline YellowThumper
  • I left the snow for this?
« Reply #116 on: April 12, 2016 - 12:00:03 AM »
 :2thumbs: very nice
Offline redo1973
« Reply #117 on: April 12, 2016 - 07:07:07 AM »
Very nice job there.  I had my air box restored but looking at yours I wonder if it was worth the money.
Offline lulurocks
« Reply #118 on: April 12, 2016 - 08:36:12 PM »
THANKS Guys!
Yeah I had to do the vintage air  setup.  My daughter is special needs and needs to stay cool in the summer , I wanted a reliable  cold system..
Offline lulurocks
« Reply #119 on: May 15, 2016 - 09:19:23 PM »
So dash in car yeah !    Steering wheel restored , American autowire kit done .  All  lamps , gauges ,signals checked.  Electrical 100% .
Front. And rear emblems on  ( took a year to get them from year one ... Grrrrrr)
  Vintage air installed and tested  ( blower,zone valves etc)
Getting car cleaned up and  final cut and buff before it goes upholstery  for headliner and vinyl roof.
« Last Edit: May 15, 2016 - 09:55:40 PM by lulurocks »
