Author Topic: 73 Challenger fuel sending unit ground strap  (Read 734 times)
Offline Chlngrcrzy
« on: July 29, 2015 - 09:44:58 PM »
Does anyone have a picture of how the grounding strap attaches? or is their another method of grounding it? i did not get a ground strap, but i will order one if necessary.
Offline tman
Re: 73 Challenger fuel sending unit ground strap
« Reply #1 on: July 29, 2015 - 10:27:59 PM »
Its basically held on by friction. See photo.  They sell all over the place.  Be sure to get the right length.  Here is a pic how its attached.
Offline Chlngrcrzy
« Reply #2 on: July 30, 2015 - 09:59:10 AM »
Thanks for the picture. Not sure what i am going to do. My fuel lines are rubber all the way back.
Offline TelisSE440
« Reply #3 on: July 30, 2015 - 10:06:06 AM »
You could tie a wire on the sending unit and put another one... say uhmmm on the screw of the exhaust hangers or on the screw of the left muffler hanger bracket bracket. I did it, it works great !!
« Reply #4 on: July 30, 2015 - 10:37:06 AM »
73's use the long strap.
My sending unit works fine and I don't have the strap in place.  I bought the short strap by accident and haven't gotten around to installing the long one.  The sending unit grounds through the tank lock ring/tank/tank straps/body.  This works when everything is nice and new but would probably stop working once surface rust starts.  This is why the grounding strap is used.  If you have a clean car underneath you don't necessarily need the strap.  You could just run a wire from the sending unit body to the frame if you wanted to.  That would accomplish the same thing.
