Author Topic: Hydro Boost for Challengers or Cudas  (Read 5998 times)
Re: Hydro Boost for Challengers or Cudas
« Reply #15 on: September 19, 2015 - 10:23:33 AM »
one build we used a hydro boost unit from an Astro van in the wrecker for $50 then we needed to make custom hoses & A mounting bracket & pushrod  to length
Offline Mpdlawdog
« Reply #16 on: September 19, 2015 - 12:10:16 PM »
Wow 50 bucks compaired to $1000. Sound like you need to start making that kit!
« Last Edit: September 20, 2015 - 08:05:20 AM by Mpdlawdog »
« Reply #17 on: September 19, 2015 - 08:47:14 PM »
I know , I need Brad to machine the mount plate , I live in the wrong place to access wreckers with vehicles that would have hydro boost units . The Teed pressure hoes will run some $$ as you need to install JIC hose fittings  , the return is simple though. As was suggested I need to look into making kits , & help from Brad but it is a doable idea .
If you are looking in the wreckers stay away from vehicles with front end damage , maybe the brakes failed LOL
