They look pretty good to me considering most of my driving is short trips and I live in a 25 MPH neighborhood.
Idles good, has good throttle response, slight flat spot or hesitation when stomping on it from idle. AFR reads 12.5-13.5 average at cruise under load. Higher at WOT (13-14 momentary 15 right when you stab it) and lower when on the idle circuit 11.5-12.5...
I'm sure there is some tweaking that could be done but I wonder if it is just fine as is and just keep an eye that it doesn't get any worse.
Maybe hit the freeway for a nice long cruise and then check them again.
No vacuum advance, 34* total timing
Rev-N-Nator, Accel Dizzy, Blaster High Vibration Coil
Crane Camshaft: SR246/362-2S-8IG , .543/.561 L/S: 104 Int. C/L: 108
Quickfuel 650 mechanical secondary
LD340 intake, factory air cleaner
Peak 480 HP @5700 and Peak 511 Torque @4300 at the crank
