Author Topic: What do these Spark Plugs tell you? #1 looks like carbon fouling  (Read 5363 times)
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
They look pretty good to me considering most of my driving is short trips and I live in a 25 MPH neighborhood.
Idles good, has good throttle response, slight flat spot or hesitation when stomping on it from idle. AFR reads 12.5-13.5 average at cruise under load. Higher at WOT (13-14 momentary 15 right when you stab it) and lower when on the idle circuit 11.5-12.5...
I'm sure there is some tweaking that could be done but I wonder if it is just fine as is and just keep an eye that it doesn't get any worse.
Maybe hit the freeway for a nice long cruise and then check them again.
No vacuum advance, 34* total timing
Rev-N-Nator, Accel Dizzy, Blaster High Vibration Coil
Crane Camshaft: SR246/362-2S-8IG , .543/.561 L/S: 104 Int. C/L: 108
Quickfuel 650 mechanical secondary
LD340 intake, factory air cleaner
Peak 480 HP @5700 and Peak 511 Torque @4300 at the crank
- Randy D.
----o00o--'(_)'--o00o----
Offline DocMel
Re: What do these Spark Plugs tell you? #1 looks like carbon fouling
« Reply #1 on: July 31, 2015 - 07:53:15 PM »
Little hard to tell due to the lighting, but I don't believe they look bad.   Most likely slow driving, stop and go might darken them up a little.  Hit the highway and see whats up.   I didnt see that you mentioned it was running bad?
« Reply #2 on: July 31, 2015 - 08:03:27 PM »
Who's plugs are they ? Part #'s?  I ask as I'm just in the middle of replacing mine due to fouling.  I used NGK R5671A-7 in Mopar stage 6 heads.
Offline Cudaragtop
« Reply #3 on: July 31, 2015 - 08:09:46 PM »
Champion RC12YC
- Randy D.
Offline Cudaragtop
« Reply #4 on: July 31, 2015 - 08:19:23 PM »
Runs fine. I'll hit the freeway for a cruise and see if it burns the carbon off.
- Randy D.
« Reply #5 on: July 31, 2015 - 08:24:53 PM »
Champion RC12YC
Thanks!  What heads are you using?
I'll be darned that the same plug I keep in stock for Briggs lawn tractors and snowblower engines. :pullinghair: As compared to the
NGK R5671A-7 I just removed the Champion plug electrode sticks out much more than the NGK.   I wonder if that would keep the carbon cleaned off/burned off better than the NGK? No one in town stocks the NGK's I use so I'm waiting till tomorrow for them to arrive. ::)
Offline DocMel
« Reply #6 on: July 31, 2015 - 08:46:07 PM »
Same plug used in most harley davidson enginee as well
Offline Cudaragtop
« Reply #7 on: August 01, 2015 - 12:16:46 AM »
I got a shop pack case of 24 July 9th on Amazon for $49.37 with shipping and now they are $64.88  :scared:
http://www.amazon.com/gp/product/B000H5R5YM?psc=1&redirect=true&ref_=oh_aui_bia_detailpage_o00_s00
- Randy D.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: August 01, 2015 - 01:36:55 PM »
Hey Randy
Looks like you are running a bit rich but better rich than too lean.
What is the gapping on those plugs? .35, .40??? it is somewhat dependent on the plug and the ignition system.
I believe mine says (MSD) to gap them between .40 - .45 but don't quote me.
B
Offline DocMel
« Reply #9 on: August 01, 2015 - 09:13:40 PM »
MSD box gaps plugs at .050
Offline AARuFAST
  • AARuFAST
« Reply #10 on: August 01, 2015 - 09:35:31 PM »
Most of the time we drive our rides local and do not get the engines fully up to temp and do a lot of stop & go.
Need to get out on the highway for a long ride......Use only Champion COPPER plugs.
the # 2 plug looks worn or pic is fuzzy.
Check distributor cab inside.
« Last Edit: August 01, 2015 - 09:40:50 PM by AARuFAST »
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline DocMel
« Reply #11 on: August 04, 2015 - 07:59:34 PM »
 :popcorn:   Well, I guess we will never know how it turned out......
Offline Cudaragtop
« Reply #12 on: August 08, 2015 - 09:38:12 PM »
Went camping for a week and just got back to my lonely laptop...
Brad, The heads are Edelbrock performer.
Bryan, the gaps are .042
Docmel, I think the pic is just a little fuzzy but I will check the cap and rotor.
If it the weather holds, I'll get it out on the freeway and check the new champs tomorrow.  :burnout:
- Randy D.
Offline DocMel
« Reply #13 on: August 15, 2015 - 06:07:47 PM »
And?
Offline Cudaragtop
« Reply #14 on: August 16, 2015 - 03:34:52 AM »
No windshield time yet... But in a few hours I'll hit the road for about a 70 mile trip south to the All Mopar Sunbust Show at Frontier Park in Graham WA.
It's the 30th year for the Sunbust show that is put on by the Tacoma WA chapter of Mopars Unlimited.
Spark plug socket and ratchet are in my tool box.  :2thumbs:
- Randy D.
