Author Topic: Car shudders  (Read 2782 times)
Offline 734406pk
  • Andy
Re: Car shudders
« Reply #15 on: August 02, 2015 - 05:46:32 PM »
Is it fair to say that the shudder is vehicle speed related not engine rpm related? Just trying to figure out what side of the trans this is on...
Offline aris_unlimited
  • Project in full swing
Re: Car shudders
« Reply #16 on: August 02, 2015 - 08:20:23 PM »
It is definitely speed related. As it does happen in neutral when going down the highway. But I have noticed when I have the hood up it looks like the engine shudders to the same rhythm when I have it running in park.
And it's newish. Been going on for a year or so and I've had the car for 5 years. I'm going to try the diff angle plates, I'm not sure it'll help I just can't remember if it started before or after I replaced the leaf springs which definitely lifted the rear end up.
Cuda is gone :(
74 satellite, daily driver/project now
Offline 734406pk
  • Andy
Re: Car shudders
« Reply #17 on: August 02, 2015 - 10:49:20 PM »
Check the torque on the flex plate to converter bolts just be be sure.
Offline 734406pk
  • Andy
Re: Car shudders
« Reply #18 on: August 03, 2015 - 08:07:36 AM »
Is the 318 there original engine for this car? Check your VIN. Maybe there was 360 CID from the factory? The converters are balanced differently between the two engines. If your seeing thei engine shudder in neutral, it's rpm related and some form of balance issue making the converter suspect. Also check your motor mounts for deterioration.
